air cond./heater fan display
Old Jan 27, 2008 | 07:13 PM
chevy01's Avatar
chevy01
2nd Gear
Default air cond./heater fan display
I just picked up a 2001 Z06, all checks out, and runs well, the only issue I have is the illuminated area of the air/heat fan is out , has anyone had this happen if so whats involved to repair?
Old Jan 27, 2008 | 07:24 PM
mcgilles's Avatar
mcgilles
if its the entire display that is out then that is a very common problem! it was the first thing I had to fix on my C5. the problem is there are 8 resistors on the circuit board inside that unit which break loose from the board and cause the display to go to its dimmest mode all the time. if that's the case you may be able to see the display faintly at night. you can fix it by disassembling the unit and resoldering them. Its actually easy to do. search around and you'll find lots of info on this problem.
if that's not it then you may have a bad HVAC interface unit.
make sure your dimmer isn't all the way down!
Old Jan 27, 2008 | 07:42 PM
chevy01's Avatar
chevy01
2nd Gear
thanks, I found the repair steps with pictures, hopefully I'll have it fixed tomorrow, cant believe its such a common problem! thanks again
Old Feb 8, 2008 | 02:30 PM
roll4speed's Avatar
roll4speed
Default get it fixed?
Where did you find the directions to fix your problem? Did you actually get the display working again?
Thanks,
R4S
To air cond./heater fan display
