twilight sentinel in 2000 c5
Old Jan 27, 2008 | 07:37 PM
J.R Rider's Avatar
J.R Rider
Cruising
Default twilight sentinel in 2000 c5
Does the 2000 c5 have them. I don't seem to have that option and have wanted this option. Guess I'm sol?
Old Jan 27, 2008 | 07:39 PM
minitech's Avatar
minitech
Mine has it. Did you look through the manual?
Old Jan 27, 2008 | 07:45 PM
J.R Rider's Avatar
J.R Rider
Cruising
I didn't get a manual when I bought the car. Is there another way to turn it off if its not in the options?
Old Jan 27, 2008 | 08:00 PM
birch64's Avatar
birch64
my 2000 has it....
Old Jan 27, 2008 | 08:09 PM
BlackZ06's Avatar
BlackZ06
If you need to see your Owner's Manual, you can go here ....
https://www.mygmlink.com/pdf/go2cont...00corvette.pdf
You can even print it out if you want a hard copy.
Old Jan 27, 2008 | 08:11 PM
RedRiderZR1's Avatar
RedRiderZR1
Not sure when it came out but my '99 has it. I have it turned off though.
Old Jan 27, 2008 | 08:12 PM
DefenderC5's Avatar
DefenderC5
My 99 has it, and it's turned off in the options. I have never used it and would give it to you if I could.
Old Jan 27, 2008 | 08:14 PM
J.R Rider's Avatar
J.R Rider
Cruising
Nothing in options on my car. Can I use tech 2 to manually turn it on?
Old Jan 27, 2008 | 08:16 PM
BlackZ06's Avatar
BlackZ06
If TWILIGHT SENTINAL is not listed when you scroll through the OPTIONS button, then the car left the factory without the option.
However, if you REALLY want the option, you need to do two things to install it.
1) Install light sensor in dashboard vent (if not currently installed)
2) Program the BCM (you will need someone with a Tech2 for this step) to turn the option to ON.
See here for some more detailed info ....
http://www.stopforce.com/RPO.html
Old Jan 27, 2008 | 08:25 PM
J.R Rider's Avatar
J.R Rider
Cruising
Good its already installed. Where would a good place to get the options set up. Does any place rent the tech2 out?
Old Jan 27, 2008 | 08:30 PM
BlackZ06's Avatar
BlackZ06
Any GM dealer (Chevy, Pontiac, Cadillac, etc) has Tech2 programmers, as do most independant shops that service Corvettes. Doubtful they would rent one, but slip the shop manager a few bucks cash and I'm sure they'll be glad to do it for you as it only takes a few minutes. Take the print-out of the steps from the link above, programming the RPO codes is not something the service guys do commonly, so it will make it faster for them and assure you it gets done right.
Don't forget that after the RPO is installed you need to go into OPTIONS and A) Be sure the Twilight is now listed and B) Set the option to ON.
Old Jan 27, 2008 | 08:32 PM
J.R Rider's Avatar
J.R Rider
Cruising
Old Jan 27, 2008 | 08:51 PM
motogib1's Avatar
motogib1
I've got that twilight sentinel option and I turned it OFF. It comes on in the middle of the day when you pull into your garage or the car wash. It is just another drain on the battery and wears the gears in you head lights out more quickly.
Old Jan 28, 2008 | 06:04 AM
bigjohn23's Avatar
bigjohn23
Old Jan 28, 2008 | 08:06 AM
bhoch's Avatar
bhoch
I have turned it off as well. I really don't like it turning on the lights when I pull into my garage at work or at home.. They were coming on sometimes when I just pulled under the covering at a gas station.
There "appears"" to to be a way to lengthen the time it delays (turns on or off the lights) but I did not see a way to change it. If it was lengthened from 1 - 2 minutes (not turn on so quickly..) I think I would use the feature a lot more as it probably would not turn the lights on when entering my garage (either at work or home) every time then.
To twilight sentinel in 2000 c5
