92mm Fast
Old Jan 27, 2008 | 11:22 PM
big hoss 98C5's Avatar
big hoss 98C5
Default 92mm Fast
any have 1 yet I would really like to see what it does ported and polished-Vern
Old Jan 28, 2008 | 08:08 AM
vettenuts's Avatar
vettenuts
From what I understand, they are only opening the throttle body hole by 2mm, the rest of the intake remains the same. I don't think there will be any difference in performance and believe it to be more of an advertising gimick to compete with some of the other intakes that have come out.
Old Jan 29, 2008 | 06:22 PM
big hoss 98C5
Old Jan 29, 2008 | 07:44 PM
happa's Avatar
happa
Old Jan 29, 2008 | 08:39 PM
Stoichiometric's Avatar
Stoichiometric
5th Gear
The throttle body and MAF will be of more restriction than the opening in the manifold. 92mm shouldn't hurt, but it is not the weakest link in the intake system.
Old Jan 29, 2008 | 09:53 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Do you work for FAST or something? That seems to mirror their shortsighted mentality.
Anyways, don't tell that to the guys with 100mm TB's and MAFs and 4" intake tubing.
Old Jan 29, 2008 | 10:02 PM
big hoss 98C5
they also have the throttle body in 92mm
Old Jan 29, 2008 | 11:17 PM
thetorch's Avatar
thetorch
The 92mm FAST is made of a different, stronger polymer material than the current intakes. They also have made 'incremental' changes to the port length and shape to further optimize the intake. This in addition to the slightly larger throttle body opening, it now has stainless hardware, threaded inserts on the throttle body flange, and an improved throttle body o-ring seal.
It's not a huge step forward from the current crop of 90mm intakes, but it's slightly better.
To 92mm Fast
