Ebay cold air kits?
Old Jan 28, 2008 | 08:34 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Default Ebay cold air kits?
These things are only $68 shipped, not much more than a K&N replacement filter, are they any good? Better than what's stock on an 01 Z06?
Old Jan 28, 2008 | 09:34 PM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
I dont know if this helps at all, but one thing you should do is check out his feedback and see what their customers have to say about the same unit, word of mouth is the best.
Old Jan 28, 2008 | 10:05 PM
ALLEGRO's Avatar
ALLEGRO
I have one very similar.
Not sure you get 20+ HP but it does involke a better intake sound and it sure could not be worse than OEM due to the increased breather area.
Mine is not chromed, but I am getting it chromed soon.
Good Luck
Old Jan 29, 2008 | 09:21 AM
Sethmo99's Avatar
Sethmo99
I've had mine for nearly two years with no issues. When I initially installed it I could actually hear the air being sucked into it! Ran straight pipes and have been having a blast ever since!
Old Jan 29, 2008 | 09:26 AM
egypt123's Avatar
egypt123
Are the filters washable?
Old Jan 29, 2008 | 09:50 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Those thing aren't any more a cold-air kit than your stock setup; to get the advantage of better air, you need something like VaraRam, Callaway Honker, or Hurricane that draws air from outside the engine bay.
I've had stock airbox, Z06 airbox & Blackwing. All were about the same in 1/4 mile runs. Switched to Callaway Honker, 1/4 mile runs improved, both ET and mph.
It's not so much about getting more air, it's about getting better air. PCM pulls timing when Intake Air Temp goes up.
Old Jan 29, 2008 | 10:04 AM
RedY2K's Avatar
RedY2K
Yes, according to the ebay listing description.
Old Jan 29, 2008 | 11:14 AM
hotwheels57's Avatar
hotwheels57
What do you think the media filtering capabilities are of an intake system made off shore and sells for $68.00?
But, if it "sounds" better and "looks" better...it's your car to do with as you please.
Old Jan 29, 2008 | 03:24 PM
Mrdrnac's Avatar
Mrdrnac
Old Jan 29, 2008 | 03:27 PM
davidfarmer's Avatar
davidfarmer
I've had a couple of these, and they work great. Most of them only have LS1 sized couplers, so some modification might be in order. However, for the money they work great. I run one on my NASA car.
Old Jan 29, 2008 | 03:41 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
but you can tell by testing the oil for silica and see how shot it is
Probably made from old Chinese socks!
Old Jan 30, 2008 | 08:19 AM
beefcake's Avatar
beefcake
got a link?
Old Jan 30, 2008 | 12:45 PM
WSPH's Avatar
WSPH
wsph
I get a little nervous about buying these no name brand parts. I am a firm believer in YOU GET WHAT YOU PAY FOR, Wait till you get the money and buy the Vararam you won't be disappointed. Do it once Do it right I say Good luck with your choice PS Just my 2cents
Old Jan 30, 2008 | 01:09 PM
nextime's Avatar
nextime
Looks like they will suck in all the hot Engine area air, if they do they are not good for any real HP increase.
Old Jan 30, 2008 | 02:24 PM
396375's Avatar
396375
St. Jude Donor '08-'09
I think for the money you will be buying a nice sound.That's about it.To check the filters run your hand on the inside of the chrome tube after some miles and see how much dust you get.I think the Y will cause some turbulence.I would rather have one large filter.If you are willing to spend more money for the right part first time I would go for something like the Callaway system.
Take care.
Old Jan 31, 2008 | 02:31 AM
Mr.Nubain's Avatar
Mr.Nubain
I just bought a BBK cold air I will let you know how it is when I install it this weekend.
Old Jan 31, 2008 | 10:52 AM
BudgetPlan1
Still not a Cold Air (despite what BBK calls it) unless you cut your shroud; otherwise you're sucking in the same hot, underhood air as the stock setup.
Fits all 1997-04 Corvette models - including Z06 models
New lightweight aluminum inlet casting
Available in titanium or chrome finish
High-flow conical filter
Add 10-15 rear wheel horsepower and show-stopping looks
System can be installed in just minutes
For about the same price of a cheap plastic cold-air kit - 1997-03 Corvette owners can now purchase one of our all-new lightweight aluminum systems. With its large conical filter and smooth cast finish in titanium or chrome - this BBK kit delivers maximum performance as well as unmatched great looks.
Not likely
To Ebay cold air kits?
Old Jan 31, 2008 | 12:27 PM
robert123's Avatar
robert123
this is not a cold air kit, just a filter.
Old Jan 31, 2008 | 01:47 PM
Vette Dog's Avatar
Vette Dog
BudgetPlan1 is right you have to cut the fan shroud in order to truly get cold air into your filters. I have the k&N FIPK and it was a very easy process.
Old Aug 9, 2008 | 05:47 PM
2kredc5's Avatar
2kredc5
I have that same intake on the C5.. Bought it for roughly 45 bucks shipped !!
No problems with it, my bro also has had one on his 99 c5 for the past 2 years with no adverse effects... (
I Definetely felt a change in the good old butt dyno) , but who knows.
This same intake is sold thru other vendors for 5 times the amount.
Ridiculous if you ask me!!!!!
Anyways... For the time being... Its a good mod that can be used in the mean time, rather than using the stock intake setup.
Shoud be worth a couple of ponies!!!
