Christmas tree in the C5
Old Jan 30, 2008 | 12:35 PM
Dudule's Avatar
Dudule
Default Christmas tree in the C5
Hi guys,
Today I had a weird stuff happening with my C5.
I was driving in town at 30 mph when I decided to move my seat forward while driving. I don't know if this is related to what happened next but as soon as I touched the button on the seat I had a wonderful Xmas tree on my dash...Every light that could be lighted was on (Security, ABS, ASR, Check Engine and so on...), the chime sounded and every gauge showed zero (Speed, fuel, batt...etc) but the engine was still running although I had "Engine reduced power" showed on the DIC followed by "Service Vehicule Soon"
Okay, I then pulled over, stopped the engine, waited a few seconds and restarted, then...everything was back to normal
Did that ever happened to you?
Old Jan 30, 2008 | 01:35 PM
kdub22's Avatar
kdub22
gremlins....
Old Jan 30, 2008 | 01:41 PM
BowTieRocket's Avatar
BowTieRocket
Or grounds. Check out Bill Curlee's post on cleaning the splice packs and ground points - it's a sticky. Did all of them on my '99, and the gremlins ran off to find another car to infest. Better than the little silver bell I used to have on my bike...
Old Jan 30, 2008 | 02:11 PM
BlackZ06's Avatar
BlackZ06
Originally Posted by Dudule
Hi guys,
Sounds like you have RPO OO7 installed on your car, by moving the seat while driving, you "armed" the system .... if you then push the FOGLAMP button, two things happen ...
1) explosive bolts blow your roof clear of the car
2) the passenger seat is launched 40 feet in the air
....... just kidding .....
There are MANY things that may have caused this ... low battery voltage, a short in the wiring .... best way to start diagnosing the problem is to display DTC data. Most likely one or more computers threw a DTC when this occured.
To display the DTC data, follow this link's instructions
https://www.corvetteforum.com/techti...D=26&TopicID=1
I'd consider displaying the codes, writing them down, and then DELETE all the DTC codes. Check again in a day or so, and see if any new codes are posted. That will go a long way toward helping diagnose the problem.
Also, consider looking at Bill Curlee's excellent sticky at the top of this forum regarding electrical issues in a Corvette. Tons of good information, and it will give you an idea how "sensitive" the C5 is to issues such as good grounds, wiring issues at the door jams, etc.
Old Jan 30, 2008 | 02:39 PM
Dudule's Avatar
Dudule
Thanks for your replies guys, I'll check if any codes are stored, if so I'll post them. Thanks
Old Jan 30, 2008 | 02:52 PM
Just say n2o's Avatar
Just say n2o
I'd bet dollars to donuts it's the battery crapping the bed. My car did some weird stuff when the battery was dying.
Old Jan 30, 2008 | 03:45 PM
Dudule's Avatar
Dudule
My batterie is 2 month old and my C5 is my DD so I use it quite often...
Old Jan 30, 2008 | 03:54 PM
Mrdrnac's Avatar
Mrdrnac
Mine too!
To Christmas tree in the C5
