A4 Transmission operating range?
Old Dec 1, 2001 | 05:10 PM
tkbillg's Avatar
tkbillg
Default A4 Transmission operating range?
Driving back from Kennedy Space Center (liftoff delayed) My transmission temperature was 199 degrees, air temp about 83 Does anyone know the normal operating range or maximum temp the transmission fluid should be at?Thanks in Advance!! :cheers:
Old Dec 2, 2001 | 12:23 AM
Duck916's Avatar
Duck916
Default Re: A4 Transmission operating range? (tkbillg)
I think the max is about 220 degrees--at some point it the DIC will reduce engine performance to prevent damage. 199 degrees, however, is fine.
Old Dec 2, 2001 | 10:22 AM
tkbillg's Avatar
tkbillg
Default Re: A4 Transmission operating range? (Duck916)
Thanks! Duck916 i looked through the owners manual and could not find it. Thanks! :seeya
Old Dec 2, 2001 | 06:01 PM
carpe dm's Avatar
carpe dm
Sounds like it is within the OK range... :)
Old Dec 3, 2001 | 03:02 AM
GTP's Avatar
GTP
199F is fine. I see between 210-215F with a trans cooler and higher stall converter. Oh and the engine won't reduce output to curb trans failure. I cleared "TRANS OVERTEMP" frome my DIC a few times while roadracing in Topeka. When I cleared the DIC it read 270F :eek:. I parked it after that.
Aaron Lephart
Old Dec 4, 2001 | 01:27 PM
Chopper Larry's Avatar
Chopper Larry
I'm thinking/hoping the "max" is a good bit more than 220. I've seen 210-218 during some spirited driving in a '98 with A4 and 2:73's. Also same with new fluid.
To A4 Transmission operating range?
