Short throw??....thoughts??
Old Jan 31, 2008 | 12:51 AM
Blackout's Avatar
Blackout
Cruise-In I Veteran
Cruise-In II Veteran
Default Short throw??....thoughts??
Looking at getting a short throw for my 01 coupe. I would go with the C6Z06 in a heartbeat...xcept i went out this past summer and purchased a flameball shift **** which i love...however the diameter of the shift rod in the C6 is different than the C5. I looked at the B&M...there not to to bad but im not looking at dropping the throw 35%....i think thats to much. Anyone have any thoughts on this?.....or has anyone done something similar?? I want to shorten the throw...just not 35%. Thanks. Ray
Old Jan 31, 2008 | 05:51 AM
vettenuts's Avatar
vettenuts
I tried the Hurst once, pulled it out after about 10 days. I then installed the C6 shifter and it was perfect and exactly what I was looking for. I am wondering if you could make an adapter or if there is one made that would allow you to install your **** on the C6 shifter. Have you asked the C6 guys in the C6 section? Maybe someone there has converted a shift ****.
Old Jan 31, 2008 | 08:08 AM
Lowcash's Avatar
Lowcash
Take a look at
http://forums.corvetteforum.com/show....php?t=1925563 .
Kevin could probably give you some info about shifters.
To Short throw??....thoughts??
