Considering a 228R from Texs Speed. Will be installing Kooks LT with X-pipe, LS6 intake and Halltech Venom-stock LS1 heads for now. Their cam kit is priced within my budget. Anyone have any eperience with this cam, or have any other receommendations? Car is a weekend driver, no track use or drags.
this cam is well liked on 'that other site'
hope you are running a 6 spd.
by cam kit I assume you will be changing springs/prods.
will this cam be on a 112cl?
i would say that you would have to have a stall. It would have idle issues when you put it in gear and it would probably hurt the low end with an auto with the stock converter
because i was thinking about a similar cam but i can't do it all at the same time so i wanted to put a cam in dyno it until i can drive it until i get the converter will that hurt the car?
Fyi Heads 226 Cam Long Tubes Fast Intake Manifld A4 Stock Converter .112lsa Car Pulled A Little At Stops . Low End Fair .3500 Rpm And Up Ran Good. Installed Protorque 2400 Ohyeah ! Hope This Helps
If you're fluent in Chinese or "crypto", yeah, it helps a lot.
Go bigger, for real. 232/236 ish would be the way I would have gone if I could do it again. BTW-I have a 224/228 114lsa now. It makes good power and is very streetable, but wish it was a bit bigger.
