help with ring around key ignition
Old Jan 31, 2008 | 01:26 PM
beefcake's Avatar
beefcake
Default help with ring around key ignition
trying to button up a couple things on the car, it's a 00'
the round ring around the key is loose, the guy tried to jerry rig it with some caulk or glue or something, i don't know
anyway, is this a piece i can just pick up from the dealer and put back in?
Old Jan 31, 2008 | 01:42 PM
Vette Dog's Avatar
Vette Dog
Hi Beef, I just added a PAc module to my stereo in order to run an amp so I had to pull the console facia off the dash. At that time I noticed that the ignition ring is held in place with a small screw (I have a 2001). But you have to take off the dash trim first.
Old Jan 31, 2008 | 01:55 PM
beefcake's Avatar
beefcake
so that little ring is held on with a screw from behind?
uggh, lol, is the dash tough to pull off?
Old Jan 31, 2008 | 02:08 PM
molson's Avatar
molson
I've broken a couple of those already... it just pushes into place.
There are 3 pins on the ignition switch that it fits over.
Very easy to break and can be bought @ the dealer for a few $$
Don't let them scam you for a whole new switch.
Old Feb 1, 2008 | 05:03 AM
BlackZ06's Avatar
BlackZ06
The bezel should be GM part number 2852046
Old Feb 1, 2008 | 08:10 AM
Irish Whiskey's Avatar
Irish Whiskey
you'll need to pull both pieces of the center console first. I done this lots of times. My black bezel is broke and moves a little bit - I just ignore it -just to "tighten" it wouldn't be enough to get me to do the work to get at it.
Procedure:
Open center console lid and remove two bolts in the back.
Open little piece of plastic just in front of it.
Loosen the power piece and disconnect the wiring.
Remove the two bolts.
Pull out the cigarette insert under the radio.
You'll see two little black "star" screws - remove.
To the left of the key hole is a little plastic cover that you remove and take out the black screw.
Console pieces are loose now - at the top of the center piece are a couple of plastic snaps be careful not to break them.
Put car in second gear and lift hand brake.
Back center console piece should be moved back as far as you can.
Loosen center piece until it clears the gear shift working it from left to right.
You are ready to "fix" the black bezel!!
Is it worth it? NO!!
Old Feb 1, 2008 | 08:17 AM
beefcake's Avatar
beefcake
the part # they gave me was 26047315
Old Feb 1, 2008 | 09:11 AM
Mac11's Avatar
Mac11
and I thought I was the only one to have this problem. I've lived with it since I shortened my shifter a few of months ago but it drives me nuts every time I stick the key in the ignition.
Old Feb 1, 2008 | 09:19 AM
BlackZ06's Avatar
BlackZ06
That part, in my parts list, is the "retainer" that "snaps" the ignition lock inside the ignition lock cylinder. If it has failed, your whole lock will pull straight out of the dashboard with the key in the ON position. (Don't try this with the battery connected - you may cause electrical damage to the vehicle - disconnect the battery before messing with the ignition lock).
The part I listed, 2852046, is the black plastic bezel that surrounds the lock cylinder mechanism. It's basically a "trim" item. Inside it, by the way, is wrapped some of the ignition lock wiring, note carefully when you removal the bezel how the wiring is wrapped so you can put the new one in correctly with the wiring.
Based on your description in your post, I believe you are looking for the bezel, rather than the retainer. The good news is, the retainer is about a $1.00 part, so you aren't out a whole lot as you probably already paid for it when you ordered it. The bezel is GM list price of $17.07 but you can probably get it for less from places such as ....
http://www.gmpartsdirect.com/
http://www.gmpartshouse.com/
Old Mar 17, 2021 | 09:07 AM
Crazy curves's Avatar
Crazy curves
You mention the wire that wraps around the black plastic cover on the ignition. That what I need to find out. How the wire goes on that. I replaced the ignition switch and checked some fuses bc c5 wouldn't start or crank. I found the bcm fuse was broken on the inside of the plastic and the car started right up, however, (all of these worked before all of this)No brake lights, no hazard lights, no blinkers. So far that's all I have noticed. Wth did I do???? Could I have done something wrong putting in the new ignition switch to cause all of that??? I am beginning to feel quite bewildered by it all. Can someone shed some light on this for me??? Thank you!
Old Mar 17, 2021 | 03:04 PM
feeder82's Avatar
feeder82
you dug up a 13 yr old thread, better to start a new thread to get your question answered. I would start checking all your fuses if you replaced the ign switch without disconnecting the battery
Old Mar 18, 2021 | 06:45 PM
Daveinnola's Avatar
Daveinnola
Ebay has them cheap.
Old Mar 29, 2021 | 06:27 PM
Crazy curves
Nope, learned right here to unhook the neg battery cable before disassembling anything on the center console, ignition, etc. But I have checked and rechecked the fuses a couple of times. That's how I finally found that the BCM fuse was broken on the inside. But not before I gave myself a few bald spots on my head. It was a great party....Not!!
Old Mar 29, 2021 | 06:29 PM
Crazy curves
Maybe that's why no one will answer my questions! I have been wondering why. If I was doing something wrong or had something set wrong to where nobody could reply. Sheesh. Thank you. I will try that.
To help with ring around key ignition
