Vacuum leak question...
Old Jan 31, 2008 | 06:30 PM
JJ 86's Avatar
JJ 86
Default Vacuum leak question...
Just finished installing a fast intake on my 98. My question is what does a vacuum leak sound like? The car idles perfect, doesn't miss, and has a smooth idle. But when you raise the rpm's slightly there's a small whistling sound. I've got a vararam also but I'm not quite sure if that's what I'm hearing. The car doesn't lack any power, no codes, etc. Could the whistling sound be a small vacuum leak or am I just paranoid? Any ideas?
Old Jan 31, 2008 | 07:56 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
These cars are very intolerant of even the smallest vacuum leak, if it had a leak big enough for you to audibly hear, it would no doubt not be a very happy runner, if all seems good and its running perfectly, i would not sweat it.
I DO recomend you get a tune if you just installed a fast intake, and youll see even better gains from it
Old Feb 1, 2008 | 08:24 AM
chevy406's Avatar
chevy406
I have the exact same issue with a recent install of a FAST intake. Car appears to run fine, but when I crack the throttle you can hear a whistle. I took the instake back off to look for any obvious signs of leaks. I reworked the MAP sensor (remote mount), but still have the same sound. I am going to try spraying starting fluid around the intake with the engine running to see if it affects RPMs. I have a wideband LM-1 hooked up, and when it is cold I am seeing some lean spike at throttle tip in, but this clears up when the engine is warm. So I don't know if it is a tuning problem or is truly a vacuum leak. When my new 30# injectors come in, I will head down to the dyno for a tune, but I want to make sure it isn't leaking before I get there....
Old Feb 1, 2008 | 09:31 AM
JJ 86's Avatar
JJ 86
I've got the same symptoms as you. Let me know what you find out. I've tried spraying starter fuild around my vacuum lines, intake base, and around the TB and the idle remains good (ildes the correct way).
Old Feb 1, 2008 | 10:58 AM
jellyjam's Avatar
jellyjam
A Chevy Van I had for 7 years with a fast idle that couldn't be fixed.Took it to a different repair shop for smog and what he did
was with an adapter on top of the carb blew smoke into the engine
and the smoke came out below the carb at the gasket and also from
two vacuum hoses to the air conditioning. This was done with the engine not running. The Van never ran better, is alot smoother and the
gas mileage increased, and yes the idle is were it should be, what a
difference a gasket and two hoses made.
Old Feb 1, 2008 | 02:26 PM
Minameisricky's Avatar
Minameisricky
I've got the same problem. It's between about 1700 and 3000 RPMs and my car runs fine. I thought it was around the throttle body but couldn't find it. Let me know if anybody figures this out, I am trying to get a dyno tune and don't want to get down there just to find out this whistle won't allow it.
Old Feb 1, 2008 | 03:52 PM
chevy406's Avatar
chevy406
Originally Posted by jellyjam
...blew smoke into the engine
two vacuum hoses to the air conditioning. This was done with the engine not running...
Good idea. I had thought about using a smoke stick with the engine running, but I never considered blowing the smoke into the intake with the engine off. I may have to pick up some smoke bombs from the local fireworks stand this weekend.
Old Feb 2, 2008 | 04:16 PM
chevy406's Avatar
chevy406
Leak testing with a red plastic tube on the spray can is an OK idea, but if you are going to trial test it by spraying into a vacuum port make sure you hold onto the tube. I let the vacuum suck the tube right up into the intake. After a 2 minute debate with myself, I snatched the intake off and shook the tube out. That gave me another chance to look it over carefully. I took the throttle body off and lapped the sealing surface (it is nice and flat). I snugged it all back down, and the noise is still there. I am going to pick up a stethascope and try to pinpoint the source. It isn't a big deal though because the car is running well. Anyway, here is a picture to document my little excursion today...
Old Feb 5, 2008 | 07:07 PM
JJ 86's Avatar
JJ 86
Old Feb 7, 2008 | 01:57 PM
Minameisricky
Anybody figure anything out on this one? I just got it smoke tested (smoke is pumped into the manifold and checked for leaks) and they didn't find anything. I'm gonna have my tuner check it out before we dyno it on mon. I will let you guys know what he says.
Old Feb 7, 2008 | 05:51 PM
chevy406's Avatar
chevy406
Last night I disconnected and plugged the vacuum port for the PCV, with no difference in the noise. I may also try plugging the small HVAC vacuum port and the brake booster line to see if that stops the whistle. I am thinking of opening up the intake again to look for internal leaks.
Old Apr 10, 2008 | 11:10 PM
kid81's Avatar
kid81
i have the same problem so I called Tech support at LG motorsport and they said it was normal and they have had alot of calls on it. I asked if it could be stopped and tech said no...
To Vacuum leak question...
