leaking coolant
Old Feb 4, 2008 | 11:26 AM
frcftw's Avatar
frcftw
Default leaking coolant
my cars leaking coolant from the bottom of the resivoir on the heater hose, i thought it was the clamp so i put one of the screw down clamps on it, it was fine for a few days and now its leaking again. is it possible its building to much pressure in the system?
Old Feb 4, 2008 | 11:51 AM
BlackZ06's Avatar
BlackZ06
Look carefully to see exactly where the leak is coming from. Could be the hose is going bad, could be that the reservoir has a crack. The system, at normal operating temperatures, does not continue to build pressure. Once the system is at a certain pressure at a certain temperature, then it stays at that pressure unless the temperature rises. Are your temperatures normal (assuming the coolant level is adequate) ?? If the temps are normal, it ain't a "pressure" issue, it is a straightforward leak. Find and fix .....
Old Feb 4, 2008 | 11:55 AM
timemender's Avatar
timemender
You most likely need a new reservoir tank. Common problem for the plastic to crack at the hose connector. Don’t try to fix with epoxy as that is a temporary fix at best. (Your call)
Gene Gulley (forum sponsor) has good prices on these. (50 bucks or so I believe – I haven’t priced one lately)
Install new rubber hoses when replacing the tank. The old hoses may be too stiff due to age.
Old Feb 4, 2008 | 12:12 PM
frcftw's Avatar
frcftw
k guys thanx the temp have been crazy or anything just normal ill pull it apart tonight and look
Old Feb 4, 2008 | 12:16 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've heard of several cracking on top of the tank at the small line, including mine too. They are only $50 therefore if it is cracked, replace it.
Old Feb 4, 2008 | 12:36 PM
BlackZ06's Avatar
BlackZ06
There are two reservoirs
1997-1999 part number 10405218
2000-2004 part number 10430189
The later tank DOES NOT have the reservoir level sensor in it.
Old Feb 4, 2008 | 12:55 PM
frcftw's Avatar
frcftw
thanx
To leaking coolant
