? about changing to T84 headlights
Old Feb 4, 2008 | 07:41 PM
04BlueGoose's Avatar
04BlueGoose
Default ? about changing to T84 headlights
Will be putting in a set of the euro T-84 Glass headlights and am wondering in there is a different gear needed vs the USA stock gear to handle whatever added weight there might be in lifting them up.
I think the 04's had a better gear than the earlier ones.
Any input?
Old Feb 4, 2008 | 08:30 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
I have had my T-84's in for over a year now and have had no problems, i also upgraded to HID in the housing and they are amazing
Old Feb 4, 2008 | 11:56 PM
thetaxman's Avatar
thetaxman
just swap them out for brass ones
Old Feb 5, 2008 | 12:00 AM
gmethod's Avatar
gmethod
I have the same set up as illmac....minus the incredible looking vette!!! The vert conversion looks sick!!! good job!
Old Feb 5, 2008 | 01:52 AM
DeeGee's Avatar
DeeGee
Mine still have the nylon gears but I have a set of brass gears in the toolbox just in case. I had a new gear under warranty in 04, fitted my Euros in 05 and no trouble since. I'd wait until you hit a problem before changing.
Check out Leaftye's sticky under the headlight section for all the info.
Old Feb 5, 2008 | 09:24 AM
Oldvetter's Avatar
Oldvetter
What conversion did you use? Do you have HIDs for high and low beams? Does the bulb move? If I could ask, how much were the HIDconversions?
Old Feb 5, 2008 | 03:31 PM
DeeGee's Avatar
DeeGee
The T84 only has a single housing normally fitted with a dual filament bulb for both high and low beam. i doubt you could fit separate HIDs in there for high & low.
Old Feb 5, 2008 | 06:49 PM
Oldvetter's Avatar
Oldvetter
DeeGee, I did an internet search, there are 3 HID systems for T84 (H4) bulbs: 1) One bulb, low beams only, 2) One bulb, it moves for high beams, 3) Two bulbs (Bi-Xenon) low and high beams
Old Feb 7, 2008 | 08:54 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
St. Jude Donor '07
here is the HID kit that i have used for my t84's HIDs this was a plug and play kit and i have had not one problem yet.H4 hi/low it is low beam HID and hi beam regular in the same bulb, they also sell a bi-xeon kit too. hope this helps
Old Feb 7, 2008 | 09:11 PM
Oldvetter's Avatar
Oldvetter
Thanks for the response. This is a 4th option that I was not aware of: Hi Halogen Bulb and low HID bulb combination.
I assume the low HID bulb stays on all with the high beams?
Old Feb 7, 2008 | 09:17 PM
aleadfoot's Avatar
aleadfoot
Thanks for the link What specific kit fits the t84 I am dense and cannot figure it out. You sound satisfied and the product looks good the PIAA's will soon pass and do not emit enough light
Old Feb 8, 2008 | 12:30 AM
Choreo's Avatar
Choreo
Had mine for about 3 years on the stock nylon gears - no problems yet, but have a brass set standing by.
Old Feb 8, 2008 | 07:13 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
St. Jude Donor '07
the lows go off when you turn the highs on, and the highs are pretty much worth less but they do fulfill the requirements for state inspection. the H4 hi/low kit is what works with the single t84 housing
To ? about changing to T84 headlights
