Runflat Tire Question
Old Dec 2, 2001 | 05:40 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Runflat Tire Question
If I go to 18's all around,can I run GY Runflats from the rear on the front? In other words, will factory rear tire fit on the front without problems? Anyone tried this? The same size wheels and tires all the way around.
Old Dec 2, 2001 | 05:56 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Runflat Tire Question (NEED FOR SPEED)
I don't think it will work because your ratios will be off. This in turn, is going to throw off TC/AH.
Old Dec 2, 2001 | 06:03 PM
jschindler's Avatar
jschindler
Default Re: Runflat Tire Question (rschiltz)
I agree with Rick. The difference is almost exactly one inch. That's a bunch. Will also look real strange - the front would sit up 1/2 inch higher. You would also likely run into some rubbing inside the fender well at full lock.
To Runflat Tire Question
