Drls ?
Old Feb 5, 2008 | 07:17 AM
555ss's Avatar
555ss
Default Drls ?
Is there an easy way to turn off the damn DRLS in a C5 I did a search on the site and found 1 post about a C6 but not a C5. The trucks are easy pull the fuse but with the BCM controlling the light what do you do
I Hate the way it looks especially on the track (pics) with the DRLS on.
Old Feb 5, 2008 | 08:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Here is how to disable them permanently and it is reversible and does not affect the operation of any other lights.
1. In the passenger foot well, lower the front carpet.
2. Remove the foot panel.
3. Locate the IPEC (Instrument Panel Electrical Center) it looks like the fuse box next to the battery.
4. Remove the cover of the IPEC.
5. Turn it over and find the diagram of the components.
6. Locate relays 38 and 40. (38 controls the right DRL and 40 the left)
7. Pull each relay and carefully remove the cover.
8. Insert some type of insulator between the relay contacts (matchbook cover cardboard or the plastic from a coffee can lid works well) that you have cut to fit.
9. Replace relay cover, replace relay, replace IPEC cover, and replace the foot well.
10. DONE!!
Old Feb 5, 2008 | 09:34 AM
Oldvetter's Avatar
Oldvetter
You should be able to pull up parking brake one or two clicks.
There is also a fuse you can pull, not sure what number, and all you lose is the parking lights flash when you lock car.
Old Feb 5, 2008 | 09:48 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You'll get the emergency brake light if you pull it up a couple of clicks and if you pull the fuse you'll disable the approach lights.
What I posted above was from another forum member and it works without causing any other problems.
Old Feb 5, 2008 | 09:59 AM
555ss's Avatar
555ss
10. DONE!!
ajg1915, Thank you very much I will try that this week. It sounds like just what I was hoping to do.
Old Feb 5, 2008 | 10:01 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No problem,
Tony
Old Feb 5, 2008 | 03:43 PM
DeeGee's Avatar
DeeGee
The easy way is to pull the A2 fuse on the engine bay panel but as ajg1915 says you'll lose the approach lights function although the reversing lights will still work. You'll also get a couple of codes.
The relay mod is the best way which is what i did. There's a full write up with pics in C5 Tech
https://www.corvetteforum.com/techti...=273&TopicID=1
Old Jun 24, 2008 | 02:38 AM
GMANS C5's Avatar
GMANS C5
I need to do this. I pulled the number 2 fuse, but I don't like losing the approach lights..
Old Jun 24, 2008 | 03:09 AM
ZeeOSix's Avatar
ZeeOSix
Anyone know what kind of wire connectors are needed for that jumper wire to connect well where the relays plug in? Does someone sell a jumper kit of some kind?
Old Jun 24, 2008 | 08:30 AM
SargeZ06's Avatar
SargeZ06
I did fuse 2 as well. What are approach lights? My foglights come on when I unlock my car with the FOB.
Old Jun 24, 2008 | 09:40 AM
555ss's Avatar
555ss
I did just what ajg1915 said it 2 of our cars and it worked perfectly
no more drls in the track pics.
Old Jun 24, 2008 | 10:57 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Glad you got it figured out.
Old Jun 24, 2008 | 10:58 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Approach lights are front fogs and rear back-ups + marker lighting.
Old Jun 24, 2008 | 12:01 PM
SargeZ06's Avatar
SargeZ06
Okay well mine still work with fuse 2 pulled. They come on and stay on with the FOB until I open the door.
Old Jun 24, 2008 | 12:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I'm not sure what fuse 2 does ?? What year car do you have ?
Fuse 2 is a monitored (inadvertent) load control - whatever the heck that means.
Old Jun 24, 2008 | 02:41 PM
DeeGee's Avatar
DeeGee
Its the A2 fuse on the engine fuse block you need to pull for the temporary fix (Approach lights). The #2 fuse on the footwell panel is the inadvertent load.
I did the relay mod to permanently disable them when I came back to UK
To Drls ?
