clutch master cyclinder
Old Feb 6, 2008 | 04:23 PM
jetmech09's Avatar
jetmech09
Default clutch master cyclinder
I will be changing the clutch master cyclinder in my o1. Is there any differance from the stock 01 clutch master cylinder from a Z06 and will it fit in a 01 vette? and how hard is it to change.
Old Feb 6, 2008 | 04:31 PM
BlackZ06's Avatar
BlackZ06
No difference, there is only 1 clutch master cylinder sold for the C5 ... Z06 or not .... GM part number 12564455.
The cylinder isn't hard to change, but bleeding the system is a PITA because unless you have previously installed a remote bleeder for the slave cylinder, getting to the bleed valve is ... well ... an effort. You will have to remove the tunnel plate to get to it.
Old Feb 6, 2008 | 09:18 PM
jetmech09's Avatar
jetmech09
ok thanks for the info.
To clutch master cyclinder
