alignment and suspenson question
Old Feb 6, 2008 | 08:00 PM
bayarea's Avatar
bayarea
Default alignment and suspenson question
what does it feel like when your shocks dont work anymore? seems like i feel everything i drive over.
also my car hasnt been driven much in the past year.
as for the alignment q, my car seems to always wanna veer to the left especially wen i accelarate.
any input on this?
Old Feb 6, 2008 | 08:15 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Your shocks, which should more appropriately be called dampers (That's what the rest of the world calls them) dampen the oscillations from your cars springs. Basically, if they are not working right your car will bounce around on you.
If you have not had your car aligned in a while I would definitely take it and and have it properly aligned at a good corvette shop. From the way you describe things sound like you are getting torque steer.
Old Feb 6, 2008 | 11:14 PM
ruffian's Avatar
ruffian
Comparing hard old tires to new tires, everything I run over now is quiet... I literally felt every little pebble with hard, old supercars. New PS2s absorb all but the harshest stuff. Even when cold.
bob
Old Feb 7, 2008 | 01:10 AM
bayarea's Avatar
bayarea
nah my tires have less than 1k miles
Old Feb 7, 2008 | 06:41 PM
bayarea's Avatar
bayarea
ttt
Old Feb 7, 2008 | 08:06 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
any input on this?
Look for a leaky shock. If there is grime all over the shock then you have a bad shock forsure. The pull can be a million differnt things.
Randy
To alignment and suspenson question
