Clutch problems!!NEED help!!
Old Feb 6, 2008 | 08:57 PM
1ynggun's Avatar
1ynggun
Default Clutch problems!!NEED help!!
Well, I got in my car lastnight and pushed the clutch to the floor and it never came back. I had to pull it with my feet. Is this the clutch or one of the cylinders? Wasn't sure if anyone had this same problem. Anyway, if it is the clutch, is there one out there that everyone recommends that wont burn my wallet, as I am trying to sell this car at the same time? Thanks guys.
Old Feb 6, 2008 | 09:19 PM
Brandon619's Avatar
Brandon619
Well you can change the clutch fluid and hope the problem doesn't come back. Is the clutch stock? Stock LS1/LS6 corvette clutches had pressure plate problems from the factory. They did not torque the pressure plate down properly.
Old Feb 6, 2008 | 11:27 PM
Matt Evans's Avatar
Matt Evans
This happened to me. Try changing clutch fluid. See member Ranger posts for an easy way to do this.
Old Feb 7, 2008 | 05:38 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
http://www.rangeracceleration.com/Clutch_Care.html
Old Feb 7, 2008 | 09:11 AM
HP_Addict's Avatar
HP_Addict
Check the fluid and bleed the clutch. If this does not fix it then the slave may be leaking and need replacement. It could be the pressure plate but unlikely.
Old Feb 7, 2008 | 09:31 AM
02gt350's Avatar
02gt350
its the stock slave/master and preasure plate...that fluid stuff is BS.
i never changed my fluid one time up till 30k miles. clutch never stuck one time. I do heads and cam, it sticks like hell on every high shift.
Old Feb 7, 2008 | 12:00 PM
1ynggun's Avatar
1ynggun
Yeah, just brought it to the shop. Said my hydrolics/cylinder was leaking really bad. So I guess they are going to fix all that, labor $ is going to be a b#t$h
Old Feb 7, 2008 | 12:13 PM
HP_Addict's Avatar
HP_Addict
Sorry to heat that. At least the part is cheap, about $180 including the throwout bearing. I would install a remote bleeder why you are in there. Also now is the time for a clutch if you think you will be needing one soon.
To Clutch problems!!NEED help!!
