Fob programming
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this step for each transmitter.
