steering column lock bypass problems
Old Dec 3, 2001 | 02:59 AM
Naylin's Avatar
Naylin
Default steering column lock bypass problems
I received the column lock bypass and have installed it. The car ran without a problem once and then when I reconnected the knee pad etc and tried the car again the problem surfaced again i.e. service steering column and the car cut out. I tried resetting the computer and disconnecting the battery and restarting the car but the problem was still there. I then rechecked the bypass and disconnected and reconnected this to the car however the problem remains. Could there be a problem with the bypass??
Old Dec 3, 2001 | 03:09 AM
Viprklr's Avatar
Viprklr
Default Re: steering column lock bypass problems (Naylin)
It is unlikely that it is the bypass. Did you try pulling fuse #25? The same thing came up on my DIC after the install. Had to pull the fuse to get it to work properly. Just pull it for 15 seconds, replace, and retest. Good luck! :cheers:
[Modified by Viprklr, 1:09 AM 12/3/2001]
Old Dec 3, 2001 | 04:04 AM
Naylin's Avatar
Naylin
Default Re: steering column lock bypass problems (Viprklr)
didn't work I'm afraid....
Old Dec 3, 2001 | 04:14 AM
Viprklr's Avatar
Viprklr
Is the wheel free to turn at this moment? If so, then you got the column unlocked. Turn the car off and pull the fuse and then try again. I'd keep trying the fuse until it works. If it doesn't, start over again from the beginning. Good luck. :chevy
Old Dec 3, 2001 | 04:27 AM
Naylin's Avatar
Naylin
thanks.. i'll try again... I'm in New Zealand so no dealers around.. makes it difficult i'm afraid...
Old Dec 3, 2001 | 05:35 AM
Naylin's Avatar
Naylin
tried a number of times .. no luck I'm afraid....
Old Dec 3, 2001 | 12:24 PM
carpe dm's Avatar
carpe dm
Is the key in the "on" position when you pull the fuse? :rolleyes:
Old Dec 3, 2001 | 04:11 PM
Naylin's Avatar
Naylin
Default Re: steering column lock bypass problems (carpe dm)
NO, key was out.. Should it be in the on position??
Old Dec 3, 2001 | 06:58 PM
B. Stewart's Avatar
B. Stewart
If I were you I would start all over again. Try using this link that has very detailed instructions. Good luck. http://97vette.com/howto/columnlock/index.html
:cheers:
Old Dec 4, 2001 | 03:41 AM
Naylin's Avatar
Naylin
Default Re: steering column lock bypass problems (B. Stewart)
started fromn scratch again including connecting the old connector and then disconnecting it before connecting the bypass.. still no luck....wonder if there is a problem with the computer. I have autotap and checked DTC's. The only DTC there is, is fuel theft deterrent signal not being received. Could I have disconnected this by mistake?
Old Dec 4, 2001 | 05:46 AM
HP-GURU's Avatar
HP-GURU
I have column lock bypass worked to a science. In short and efficient jerks turn wheel left and right at a rapid rate.
Turn key to the on position. The wheel should "break free".. LOL.
I haven't had CL since weather got cooler. But got used to "breaking free".
Old Dec 4, 2001 | 11:15 AM
Denyce Codoni's Avatar
Denyce Codoni
Maybe you guys can help me. I installed the bypass months ago & it works but everytime I start the car I get "pull key wait 10 seconds". If I don't, the car dies. So, I have to pull the key and try again. I don't have to wait 10 secs, but it's really annoying. I was sent a new bypass to see if the original was defective, but no change. It sure beats a locked steering wheel, but if there is a "new" solution out there, I'm game.
I've been off the forum for a while, so maybe this is an old question. If so, I apologize.
Old Dec 4, 2001 | 03:58 PM
shockwave's Avatar
shockwave
Default Re: steering column lock bypass problems (Denyce Codoni)
Did you try to pull the fuse #25? This sometimes fixes the problem you have once and for all...
Old Dec 4, 2001 | 06:44 PM
Denyce Codoni
Default Re: steering column lock bypass problems (shockwave)
Been there - done that. I pulled 25 & I think 32 and whatever else was recommended - still no change.
Old Dec 4, 2001 | 06:50 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Denyce and Naylin,
Shoot Tom at c5solutions@att.net an email. He is very helpful as the maker of the bypass. Perhaps he has had success in troubleshooting your problems.
RG
To steering column lock bypass problems
