Do 18x12s rub?
Old Feb 8, 2008 | 06:35 AM
COUTO1981's Avatar
COUTO1981
Default Do 18x12s rub?
Im told by some (the one's selling them) that do not rub but z06s need to remove the air duct, by others that they rub...
any experience with these, I assume base and Z06 have the same clearance?
Old Feb 8, 2008 | 12:52 PM
Z O SICK's Avatar
Z O SICK
if the offset if correct, then you'll be fine. I'm running 18 x 12's with no issues. They are aftermarket Z06 rims. I hope this helps.
Old Feb 8, 2008 | 01:38 PM
tiojames's Avatar
tiojames
If you buy the rims with the proper offset for the C5 they will clear. I run 3.35s on 12" rims also.
Old Feb 8, 2008 | 03:50 PM
COUTO1981's Avatar
COUTO1981
thanx everyone, what would that offset be??
Old Feb 8, 2008 | 08:39 PM
Double G's Avatar
Double G
ttt
Old Feb 8, 2008 | 09:59 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default pic anyone?
I would love to see this!
Old Feb 8, 2008 | 10:08 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I'm running 335s on a 18x12 CCW but had to remove the rear brake cooling ducts for clearance.
Old Feb 9, 2008 | 06:30 AM
JETZ's Avatar
JETZ
You forgot to ask the other question...do they stick out!
Old Feb 9, 2008 | 07:36 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Let's here the answer, oh no more than a inch or two.
Old Feb 9, 2008 | 09:12 PM
XtremeVette
Default nobody has a picture?
pics anyone?
Old Feb 10, 2008 | 12:48 AM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
18x12's with Nitto 335's. 1/4" spacer in the rear. The angle of these shots kind of make them look like they stick out farther than they really do. I can get some better shots tomorrow.
Old Feb 10, 2008 | 11:42 PM
Brad@RevXtremeAutoSports's Avatar
Old Feb 11, 2008 | 07:15 AM
AU N EGL's Avatar
AU N EGL
Of course not, when you stick 3/4" wider fenders on.
To Do 18x12s rub?
