Wheel Hop: Why C5 does but C4 does not?
Old Feb 8, 2008 | 01:43 PM
sothpaw2's Avatar
sothpaw2
Default Wheel Hop: Why C5 does but C4 does not?
Hi,
I have an '02 Z and am curious as to what causes it to wheel hop, as opposed to just spinning the rears when traction is not enough. This is a stock car other than headers & tune w/ stock 295-35-18 F1SC's which are new (6 months old now but purchased new). Maybe it's making ? 375 rwtq?
I had a C4 with head and cam that made 336 rwtq and 360 rwhp. On 275-40-17 F1SC's it never hopped. In fact, when stock, the C4 never wheel hopped on the 285-40-17 GSC's. True on the street or strip.
So what in the suspension causes the car to hop as opposed to spin em'?
Is it the aspect ratio of the tire?
Old Feb 8, 2008 | 02:29 PM
sothpaw2's Avatar
sothpaw2
Originally Posted by 8VETTE7
Do a search on WHEEL HOP and you will see a lot of threads about this issue. Cold tires, cold ground, shocks, bushing mounts that are not urthane, Run Flats vs non Run Flats, etc.
I'd suspect that since you hale from MD, and I'd bet it's still pretty chilly back there, that the cold tires and cold ground are your chief causes this time of year. Watch the hop as it can result in lots of broken components if you insist on standing on that pedal on the right.
Chuck S.
I know what you mean about the cold but what I'm getting at is why don't they just SPIN? The C4 would spin, never hop.
I get a hop at the drag strip even in warm with a low rpm launch, for instance, where the c4 would just spin in a similar circumstance.
Old Feb 8, 2008 | 04:17 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^Not sure of the answer to your question but perhaps it is due to where the transmission is placed on the C5 versus C4. The C5's tranny is in the rear whereas the C4 is up next to the engine.
Old Feb 9, 2008 | 01:17 AM
ISeeRed's Avatar
ISeeRed
Not too well versed but it has something to do with harmonics of the rear transaxle. They solved it on the ZR1 by using unequal sized half shafts. It changes the harmonics so it doesn't wheel hop.. Apparently they did this with the new Cadillac V's also...I read an article about it!
Old Feb 9, 2008 | 01:26 AM
HIGHRPM's Avatar
HIGHRPM
My '99 never hopped even when it was stock..... and as the rwhp went from 300 to 850....never had wheel hop..... one of the first mods I did was to swap out the stock shocks for a set of adjustable HAL QA1s...I set the fronts at 4 the rears at 6....no hop....just alot of spinning and smoke. You might want to try swapping the stock shocks for a set of adjustables....you can set the QA1s to eliminate hop.
Old Feb 9, 2008 | 01:31 AM
petercln's Avatar
petercln
Originally Posted by HIGHRPM
My '99 never hopped even when it was stock..... and as the rwhp went from 300 to 850....no wheel hop..... one of the first mods I did was to swap out the stock shocks for a set of adjustable HAL QA1s...I set the fronts at 4 the rears at 6....no hop....just alot of spinning and smoke.
Shocks are very important. Along with the spring rate. I think that the z06 springs may be to stiff. Softer springs along with a firmer shock is the ticket. imho
Old Feb 9, 2008 | 01:56 AM
Bill Dearborn's Avatar
Bill Dearborn
Despite people claiming cold tires cause the problem I had it get worse as the tires got warmer. Cold wet tires wouldn't do it but with multiple passes on a start/stop (acclerate as hard as you can from a marker then jam on the brakes and stop with the nose of the car over a certain point) course in the rain the more passes I made the worse the hop got. The tires were steaming on the last few passes.
Bill
Old Feb 9, 2008 | 10:56 AM
sothpaw2's Avatar
sothpaw2
So you folks w/ coupes don't get any hop? Can more of you chime in? Very interesting.
I have heard about shocks but since I take this car on the road course I am very reluctant to mess with the shocks as I don't know well enough what I'm doing to tune them right.
Sounds like this really re-affirms that the Z06 is for the road course and not the drag strip.
Old Feb 9, 2008 | 11:33 AM
brent02's Avatar
brent02
Yes, I went from the stock FE1 suspension to the FE4(ZO6) and I now get wheel hop.
Old Feb 9, 2008 | 11:40 AM
ISeeRed's Avatar
ISeeRed
I will say that I have the adjustable suspension in my car and wheel hop improves when I go to the stiffest setting. The softer setting promotes more wheel hop. I don't always get it..... Just under some conditions. It mostly starts when I just roll or ease on the throttle and it starts to break traction.
Old Feb 9, 2008 | 03:02 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
99 Coupe, 6spd, F45
I usually have it on "tour", so I dont know about the other 2 settings, But I never experienced wheel hop in the car until I moved here where I was able to drive longer into fall/winter, and the tires were cold.
After about 10 mins or so of driving the hop was gone.
Old Feb 12, 2008 | 04:22 PM
robert123's Avatar
robert123
Cold asphalt is a big factor. The runflats are another. I rarely have wheelhop issues in the summer.
Old Feb 12, 2008 | 04:54 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Chuck S.
I would get wheel hop from time to time in my FRC. Poly buhings have really helped some people along with decent tires.
I never wheel wheel hop in my C4 either.
Old Feb 12, 2008 | 04:57 PM
ISeeRed's Avatar
ISeeRed
I agree with the C4 bit. I never had wheel hop in any of the four of my C4's. The torque tube from the trans just caused the thing to spin. The C5 is another story. I don't have big issues.....but once in a while........
Old Feb 12, 2008 | 09:01 PM
mcgilles's Avatar
mcgilles
I have a 99 6 speed with F45.
I spun the tires a few times over the holidays just having fun. the ground was usually wet making it easier to break traction. if I dropped the hammer while standing still the wheels would spin, if I got car rolling first then hit it it would wheel hop every time. as long as I was actually doing a burn out it would spin smoothly.
Old Feb 13, 2008 | 08:52 PM
C5Bagger's Avatar
C5Bagger
Have a 2001 A4 Z51 315 rear Vert, warm weather dead stop, floor it no wheel spin it just lanches, is this normal? do other autos spin? 22K runs great?
Old Feb 14, 2008 | 12:15 AM
Quickshift_C5's Avatar
Quickshift_C5
My FRC hops like mad. It's extremely irritating. I just order new wheels that are a bit wider. Going to toss on some totally different/better tires and see what happens.
I'd do anything to get rid of that lame wheelhop.
To Wheel Hop: Why C5 does but C4 does not?
Old Feb 14, 2008 | 06:55 AM
irokru's Avatar
irokru
No hop untill lowered car .... then hop begain .... Something in lowering
caused a changed that allowed hop to occur.
Old Feb 14, 2008 | 09:05 AM
wisky's Avatar
wisky
My FRC hops like crazy also, I assumed it was because of the freezing temperatures. When spring time comes around, I would hope the car could hook up better, and totally eliminate the wheel hop.
Old Feb 14, 2008 | 09:14 AM
tompugh's Avatar
tompugh
My 99 coupe hops like crazy. 99, 6 speed, stock. Launch technique seems to be key. With traction control off, I need to bring the rpms up to about 3000 then slip the clutch a little and she spins, no hop. If I just try to punch her out of the hole from idle or 5-10mph role she hops. TP
