Wheel Hop: Why C5 does but C4 does not?
On live axle cars like F-bodies or Mustangs, wheel hop can be very violent, but also very easy to solve. Most of the time, it is the result of lowering the car, which changes the angle that the Lower Control Arms are at. They sell brakets to relocate the LCA's if you lower your car.
I never had any wheel hop on my 2.73 TransAm, but when I changed the rear to a 3.42, the whole rear felt like it was going to fall off it shuddered so bad at times. Upgraded shocks helped a little, but I relpaced the rear with non-binding poly-bushing LCA's and the problem went away. Even upgrading to 3.73's, I still don't have any issue.
Spring rates, damping and tires affect wheelhop in an IRS car. Idealy, you wouldn't have any suspension, it would all be hard connected to get maximum transfer, but that's unrealistic in the real world. Also, rear end ratio make a huge difference, since upgraded rear cars would be more likely to overpower the tires and get hop. Tires make a huge difference, followed by the shock and spring upgrades. All the drive angles then come into play, and lowered cars are going to be worse.
The ZR1 is supposed to solve issues by using variable damping shocks that when the computer sense a hard launch, it softens the rear shocks to allow the car to squat, then immediately firms them up. I also saw something about using different sized output shafts. Maybe that's what another poster refered to as harmonically tuning.
As for C4's, I don't think wheel hop is an issue since they didn't have enough power to overcome the tires, but maybe someone with a modded C4 can speek up.
