Better fog lights
Old Feb 9, 2008 | 12:48 AM
pro1955's Avatar
pro1955
Default Better fog lights
Does anyone have suggestions on fog light replacements. I have one burned out and I've always thought they sucked, not enough output. Is there a better way to go?
Old Feb 9, 2008 | 02:26 AM
thetaxman's Avatar
thetaxman
885 bulbs if you want to use the stock housing
Old Feb 9, 2008 | 04:59 AM
molson's Avatar
molson
Or you could use the stock housings an get an HID kit......
jdmvette had a great thread showing his inexpensive conversion.
http://forums.corvetteforum.com/show...=hid+foglights
Old Feb 9, 2008 | 06:09 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
bad link molson ?
Old Feb 9, 2008 | 07:57 AM
Oldvetter's Avatar
Oldvetter
These are 50 watt clear end bulbs as opposed to the stock 37 watt black end. You then must re-aim them (they are way too low from factory), use small hole, it takes a torx (think #15).
Mine have been this way for years, I use them everytime the low beams are on, no problems.
On the other hand, these fog lights do have a great cutoff pattern and will take HID conversion well. You should be able to drive with only them after HID conversion. They should be better than converting the stock headlight lenses (they have too much scatter). Only bad thing is that the fog lights go off when the high beams are on. It would be good to re-wire these.
Old Feb 9, 2008 | 09:21 AM
ZNFUL-Z06's Avatar
ZNFUL-Z06
first step 50 watt 855
second step HID with ballast
Old Feb 9, 2008 | 09:33 AM
molson's Avatar
molson
Originally Posted by mrm1149
bad link molson ?
Sorry ....:o
Fixed now
Old Feb 9, 2008 | 09:41 AM
taz03's Avatar
taz03
I did the hids and it is a huge improvement. They are not that expensive either. That is what i would suggest.
Old Feb 9, 2008 | 10:31 AM
bighank's Avatar
bighank
Default Best change for $2
You could spend $100 plus for PIAA or the like but the 50 watt 885 bulbs almost let you drive without headlights. Reaim them with the torx driver thru the little hole on the shroud about 15 or 20 feet from your garage door or a wall. Use the low beams as a guide. You will be surprised at the difference. BIGHANK
Old Feb 9, 2008 | 02:10 PM
jrprich's Avatar
jrprich
Or spend about $100 for a 800 series HID kit and a dedicated wiring harness and turn thos OEM projectors into REAL lights They will blow the PIAAs out of the water and take less time to install.
Old Feb 9, 2008 | 06:07 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
See my post on the install
http://forums.corvetteforum.com/show....php?t=1687872
Toque
Old Feb 9, 2008 | 10:56 PM
Nick1's Avatar
Nick1
I installed the higher wattage bulbs and found them to be a great improvement at low cost!
Old Feb 10, 2008 | 05:48 PM
docohm's Avatar
docohm
I really like the PIAA lights I put on in place of the stock lights. They light things up better than the stock low beams!
DocOhm
Old Feb 10, 2008 | 06:11 PM
thetaxman's Avatar
thetaxman
DocOhm
kinda defeats the purpose of fog lights
Old Feb 11, 2008 | 12:33 AM
pro1955's Avatar
pro1955
Anyone know the best place to buy both the 885 bulbs and HID kits? Maybe a link to go to. thanks for the info guys.
Old Feb 11, 2008 | 02:31 AM
thetaxman's Avatar
thetaxman
885's are available at almost auto parts store
Old Feb 11, 2008 | 09:38 AM
jrprich's Avatar
jrprich
CF rules prohibit ebay links. Just search HID Kit and sort by lowest price shipped
Old Feb 11, 2008 | 01:48 PM
pro1955's Avatar
pro1955
Thanks again, I'm going with the HID kit.
To Better fog lights
