determining gear ratio
Old Feb 11, 2008 | 12:40 PM
largeitalian's Avatar
largeitalian
Default determining gear ratio
is there a way to determine gear ratio via cruising speed and rpms? I need to know whether I have 273 321 or 342
Old Feb 11, 2008 | 12:51 PM
AU N EGL's Avatar
AU N EGL
have you changed your transmission or Diff?
Old Feb 11, 2008 | 12:53 PM
RespondsWithGif's Avatar
RespondsWithGif
I got this from: http://mikemercury.home.att.net/ratio.htm
C. Or... place your A4 into third gear and get on the highway. At a constant 75mph (making sure the TC has locked) read the rpm value; then divide it by 1000.(This also works with the six speed manual transmission using 4th gear):
Old Feb 11, 2008 | 02:19 PM
largeitalian
thank you coupe that link was very helpful!
To determining gear ratio
