Passenger Wheel Well Access Panel Question
Old Feb 10, 2008 | 07:38 PM
george's2001c5's Avatar
george's2001c5
Default Passenger Wheel Well Access Panel Question
Do you have to remove the tire to access the the panel and get it off. any one have pictures or this asking for too much. Thanks in advance you guys are great.
Old Feb 10, 2008 | 09:15 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
You can proably get it off without removing the tire but it will be much easier if you remove the tire.
It is very easy. There are 6 or so screws in the wheel well and 2 or 3 under the car that you can easily see.
Old Feb 11, 2008 | 09:17 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^ except I would definitely take the tire off. There is not a lot of room to work there. My brother and I took the rear ones out yesterday when we were droppong the driveline.
Old Feb 11, 2008 | 09:56 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Easier with tire removed!
It will depend as to why you need to remove it, so if you need room then take it off but if it's for cleaning the area out with a shop vac you should be good!
It is easier to do a thurough inspection with the tire removed
Thanks,Matt
To Passenger Wheel Well Access Panel Question
