Look What I Did!!
Old Feb 10, 2008 | 09:35 PM
happa's Avatar
happa
Default Look What I Did!!
I bent a valve and I then bought some new LS6 heads. So I went ahead and fly-cut the pistons. Just wanted to share my experaince!
It was a little scary at first but very easy!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Feb 10, 2008 | 09:43 PM
lucky131969's Avatar
lucky131969
How did you go about removing material from the pistons?
Old Feb 10, 2008 | 09:52 PM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
The Head Of The Piston Is Only So Thick. Just Curious. How Do You Prevent Piston Failure As A Result Of This Grinding?
Old Feb 10, 2008 | 09:58 PM
happa's Avatar
happa
I just vacuumed it out really good right after each cut. It worked better than I thought it would. The guy that help me said thats how he's done all his jobs and never had a problem. Ive been diving around for over 100 miles now and havent had any problems.
Old Feb 10, 2008 | 10:03 PM
happa's Avatar
happa
I have the G5X4 and there is some clearance to where if you dont over rev it you'll be fine. Well I over reved it and "kiss the piston". I only cut .040" so that little bit gave me enough clearance so this want happen again. I did a lot of searching and it seems that .040" is enough without damaging the piston.
Old Feb 10, 2008 | 10:05 PM
lucky131969
My question was related to what method you used to cut the pistons, not how you removed the shavings.
So you removed an amount of aluminum from each piston? Since this was done post assembly, I would surmise your rotating assembly in no longer in balance.
Old Feb 10, 2008 | 10:14 PM
happa's Avatar
happa
Oh sorry, misunderstood yea. I used a cut-up ls1 head and they make a tool for fly-cutting the piston. I didnt get a chance to take a pic of the tool. Its pretty much looks like a valve with 4 blades on it. Kinda wild lookin. We attached a cordless drill to it and let it rip. It being aluminum it was very easy to cut. We also used a set of calipers and a depth gauge to make sure we only cut .040" and not more or less.
Old Feb 10, 2008 | 10:27 PM
lucky131969
What type of valve springs were you running when you floated the valve?
Old Feb 10, 2008 | 10:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
At it's thinnest point, it's about .250" thick.
I flycut all my pistons .100" deep for intake valve clearance, no problem.
Old Feb 10, 2008 | 11:39 PM
happa's Avatar
happa
I guess I was being too conservative. Hope i did cut enough!
Old Feb 10, 2008 | 11:41 PM
happa's Avatar
happa
Im using Precision Race Component Double Valve Springs.
Old Feb 10, 2008 | 11:51 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I'm running milled heads and .040" gaskets...I cut .100" deep and ended up with .090" actual p/v clearance.
That means just spinning the motor over by hand, the valves are falling .010" into the pockets I cut. Had I not cut at all, there would have been contact.
If you float a valve, I'm not sure .040" would really make much of a difference. I also wonder how you did so. MY PRC duals are doing fine at 7000 rpm.
Old Feb 11, 2008 | 09:14 AM
UWEBABY's Avatar
UWEBABY
Very Interesting. Thanks Y2k.
Old Feb 11, 2008 | 09:59 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
How did you know how much material to take off?
It would seem that if one is more than the others it could be out of balance and lead to some vibration or other serious problems later down the road.
It looks real clean but I hope all is good! and I love the cutawy of the LS Head!
Thanks,Matt
Old Feb 11, 2008 | 10:52 AM
ArKay99's Avatar
ArKay99
The only other thing I would have done is rounded the edges of the eybrow to keep from generating hotspots which could cause ping.
To all those concerned about balance. I did this about a year ago on my motor. I had a small cam but on a 112 and had minimum clearance so I cut .060" on both the intake and exhaust. The weight of that much material is less than .5 gram and didn't put the engine out of balance any I could tell. In fact it seemed to run a little smoother. The fact that the weight removed is reciprocating weight rather than rotational weight also makes it less of a factor.
Old Feb 11, 2008 | 11:24 AM
ZZOOM06's Avatar
ZZOOM06
I cut .080" when I did my H/C install. Used a cut up LS1 head and the Isky Tools. That was 15k miles ago and no problems whatsoever.
Jimbo
Old Feb 11, 2008 | 04:23 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You would have to remove a lot of material from the reciprocating assembly before you even began to notice it, this little bit of fly cutting is nothing
To Look What I Did!!
Old Feb 11, 2008 | 04:36 PM
happa's Avatar
happa
hmm, Im not 100% sure that I bent a valve, another thing I could have done is messed a lifter up. I had bumped the rev limiter just for a sec and the sqeeking and back firing began. So my first thought was bent valve and then I heard that messing a lifter would cause similiar problems. So I fixed both and got new heads and LS7 lifters Man I hope i cut enough, but if your rev is at 7k, mine is at 6700 I guess I might be ok. We checked clearance and it seemed really good, so I guess I can hope this wont happen again.
Old Feb 11, 2008 | 04:38 PM
happa's Avatar
happa
Thanks,Matt
I did a lot of searching and found a safe amount to cut. I might have been to conserative, but hopefully enough. I guess we'll see when I take down the track!
Old Feb 11, 2008 | 04:40 PM
happa's Avatar
happa
I did, I took a real fine round file and filed away. Made sure there where no sharp edges. I cant really notice If my car runs smoother the 111 lsa will hide that!
