Headlamp Problems
Old Feb 12, 2008 | 04:05 PM
Thegdog's Avatar
Thegdog
5th Gear
Default Headlamp Problems
At night my headlamps go off for short periods of time while driving. After 30 seconds or so they go right back on again. Who can help????
This is on a 2000 C5 Coupe
Old Feb 12, 2008 | 04:09 PM
DeeGee's Avatar
DeeGee
I'd start with grounds and the battery connections. give them a clean up and tighten the connections
Old Feb 12, 2008 | 04:27 PM
Thegdog's Avatar
Thegdog
5th Gear
Yes, I started there by looking at the connections, but the problem continues. No loose wires either....
Old Feb 12, 2008 | 04:48 PM
Oldvetter's Avatar
Oldvetter
Check your codes.
Document ID# 562101
2000 Chevrolet/Geo Corvette
Headlamps Inoperative - Low Beams
Low Beam Headlamps Inoperative Step
Action
Value(s)
Yes
No
DEFINITION: Low beam headlamps are inoperative, high beams are functional.
1
Were you sent here from the Lighting Systems Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Lighting Systems
2
Disconnect connector C209.
Connect a fused jumper wire in the harness side connector C209, between terminals W and L.
Do the low beam headlamps illuminate?
Go to Step 4
Go to Step 3
3
Remove one of the low beam headlamp fuses.
HDLOBML MiniFuse® #10
HDLOBMR MiniFuse® #8
Connect a DMM from the fuse terminal B in the underhood electrical center, to the harness side connector C209 terminal L.
Measure the resistance of circuit 12.
Is the resistance within the specified values?
0-2 ohms
Go to Step 5
Go to Headlamps Inoperative - One Lamp
4
Replace the headalamp switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle .
Is the repair complete?
Go to Step 6
5
Repair the open or high resistance in circuit 12.
Go to Step 6
6
Clear any DTCs which may have set. Refer to Diagnostic Trouble Code (DTC) Clearing .
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Document ID# 562101
Also try:
Headlamps Inoperative - Low and High Beams
Low/High Beam Headlamps Inoperative Step
Action
Value(s)
Yes
No
1
Go to Step 2
2
Remove the HDLP MaxiCircuit Breaker #54.
Using a DMM measure the resistance to ground of circuit 842, from the harness side connector C209 terminal W to ground.
Is the resistance within specified values?
Infinite
Go to Step 3
Go to Step 10
3
Connect a DMM from the HDLP MaxiCircuit Breaker #54 terminal in the instrument panel electrical center, to connector C209 terminal W.
Measure the resistance of circuit 842.
0-2 ohms
Go to Step 4
Go to Step 10
4
Measure continuity of the HDLP MaxiCircuit Breaker #54.
Is the circuit breaker open?
Go to Step 6
Go to Step 5
5
Reinstall the HDLP MaxiCircuit Breaker #54.
Go to Step 7
6
Install a new 20 A MaxiCircuit Breaker in the HDLP #54 location in the instrument panel electrical center.
Go to Step 7
7
Connect a fused jumper wire in the harness side connector C209 terminals W to L.
Go to Step 12
Go to Step 8
8
Connect a fused jumper wire in the harness side connector C209 terminals W to K.
Do the high beam headlamps illuminate?
Go to Step 11
Go to Step 9
9
Replace the headlamp switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle .
Go to Step 13
10
Repair the open or short to ground in circuit 842.
Go to Step 13
11
Repair the open or short to ground in circuit 11.
Go to Step 13
12
Repair the open or short to ground in circuit 12.
Go to Step 13
13
System OK
Document ID# 562933
Old Feb 12, 2008 | 05:25 PM
Thegdog's Avatar
Thegdog
5th Gear
Thanks!
Old Feb 13, 2008 | 11:43 AM
Oldvetter's Avatar
Oldvetter
Originally Posted by Thegdog
Thanks!
Your welcome, hope you get it fixed. Intermittent electrical problems are tough to fix. Seems like a short in the "circuit breaker" circuit or perhaps a bad circuit breaker.
To Headlamp Problems
