Short throw shifter questions
Old Feb 13, 2008 | 08:31 AM
LDB C5's Avatar
LDB C5
Default Short throw shifter questions
I am considering going with a short throw shifter in my 01 vert. I am pretty impressed with the MGW product, but unsure about which one 25% or 35% shorter.
I played around with a 2008 C6 Z06 shifter at the Auto Show in Chicago earlier this week and was not overly impressed. Sure the throws are shorter, but it still felt "sloppy" IMHO. Anyone have comparative experience with these, or the Hurst or B&M for that matter?
Other mods in sig below
Thanks In Advance!
Old Feb 13, 2008 | 08:35 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
My feelings on the C6Z shifter were the same as you. Shorter than stock, really light feel, but still had that factory sloppy feel. This was after installing in a forum members car.
I have a Hurst in my car personally, and though it's notchy and stiff, it's very short and quick, and I love it.
Old Feb 13, 2008 | 10:32 AM
lucky131969's Avatar
lucky131969
Hurst here. Very precise shifting, and short throw. Easy to install. You will really have to go out of your way to blow a shift with this shifter.
Old Feb 13, 2008 | 11:24 AM
ZZOOM06's Avatar
ZZOOM06
Love my Hurst!
Old Feb 13, 2008 | 11:26 AM
evil frc's Avatar
evil frc
Hust all the way
When I first installed mine it was very stiff.
After a week or two it is just right.
Not so much notchy as pricise.
Viperbluelx was going to cut a factory unit and test the results but havn't heard if he has done it or the results.
It would be shorter, but still sloppy I would imagine.
Old Feb 14, 2008 | 06:56 PM
glide's Avatar
glide
St. Jude Donor '13,'19
Default Mgw
I went with the MGW 35%. They also make a 25%. Shifts are very precise "gunbolt" action like. A thousand times better than stock. Install was easy and took about 1.5 hours. Do a search on shifter and you'll find tons of info. The problem with most after market shifters is noise. Not so with the MGW. It does take a little effort but doesn't bother me. If I was a girl (or a wimp) I would go for the 25%. Mine's still pretty stiff but I've only had it a couple weeks or about 100 miles. Maybe it'll get easier. Hope that helps.
Old Feb 14, 2008 | 07:11 PM
hotwheels57's Avatar
hotwheels57
I recently installed a B&M "Sport", similar in vibration dampening design as oem, shortened shift throws, absolutely no noise or vibrations.
Old Feb 15, 2008 | 06:57 AM
BitViper's Avatar
BitViper
Ditto....
Old Feb 15, 2008 | 09:53 AM
WKMCD's Avatar
WKMCD
I've had:
Stock -
B&M Ripper - Too stiff for driving in traffic
C6 - Much better than the C5 but still sloppy with 1st gear engagement questionable regardless of adjustment.
MGW 25% - PERFECT
Old Feb 15, 2008 | 06:49 PM
ecoman's Avatar
ecoman
Been thinking about a hurst myself do they make a lot of rattling noise?
Old Feb 15, 2008 | 07:07 PM
fastbluels6's Avatar
fastbluels6
St. Jude Donor '10
Hurst! lol B&M and im lovin it. oh and after u beat on it for awhile they all rattle nature of the beast.....
Old Feb 15, 2008 | 08:01 PM
Greg_E's Avatar
Greg_E
Originally Posted by evil frc
Hust all the way
If you want to shorten a stock shifter, here is one way to do it that will eliminate the sloppy feeling of the stock shifter. If you want even shorter throws, you can cut the threaded end after you've done this mod. You need to get rid of the rubber insert, or the shifter will still feel sloppy. It goes easily into all gears including reverse and doesn't rattle. It may not be as good as the aftermarket shifters, but it's a huge improvement for almost no money.
See post #9
http://forums.corvetteforum.com/show...ghlight=Greg_E
Old Feb 15, 2008 | 08:50 PM
blkdevl's Avatar
blkdevl
im probably going with the hurst i have it in my z28 and i love the knotchy fealing it goes into gear everytime.
Old Feb 15, 2008 | 11:05 PM
geterdone's Avatar
geterdone
One of the best things about a aftermarket shifter is that it a lot easier on your tranny.
Old Feb 19, 2008 | 11:25 AM
glide's Avatar
glide
Really? How so?
Old Feb 20, 2008 | 08:39 PM
Johnny Hardcore's Avatar
Johnny Hardcore
B&M Ripper here. I love it. Yes, it is a bit stiff in traffic, but nothing a gym membership can't fix.
My brother has the Hurst and it's a bit notchy compared to the B&M. The B&M is stiff, but it slams like the shifter in a sports car should.
Old Feb 20, 2008 | 08:45 PM
tommybilt's Avatar
tommybilt
I bought a hurst. Should have been one of the first mods I did.
To Short throw shifter questions
Old Feb 21, 2008 | 01:04 AM
redroket's Avatar
redroket
Default shifter
I changed to a Kirban Kwik Shift and it is excellant. Yes it is still a bit notchy but there is no way you are going to miss a shift like with a stock shifter. The ease of shifting is still easy, you don't have to start lifting weights to change gears! I also cut off 1" off and threaded down another 3/4" to make the shifter shorter which seems to work just fine.
good luck with whatever you do!
Old Feb 21, 2008 | 10:54 AM
speedsk899's Avatar
speedsk899
I have never played with the Hurst, But I love my B&M! Some say it is to stiff but it comes with three sets of springs. You can set it up how ever you feel.
Old Feb 21, 2008 | 09:01 PM
Dave concrete's Avatar
Dave concrete
How about the breathless? My bud swears by this thing.
