Having a hard time understanding
Old Feb 13, 2008 | 06:52 PM
bobby777's Avatar
bobby777
Default Having a hard time understanding
Traction control-active handling-competive mode--please explain how they work and how i turn all 3 off-on--thanks
Old Feb 13, 2008 | 07:23 PM
Zee916's Avatar
Zee916
Hit it once and that turns traction OFF, everything totally off, no electronic help. This will allow you to do whatever with the car and it will not interrupt at all.
Holding the button down will put you into Comp mode which will allow AH to work but turn the traction control off. Most people like this the best as it doesn't allow you to get squirly side to side if the tires do break loose.
If you like to pedal the car and really drive it with no aids just hit it once.
Just a reminder to be super careful if you turn it all off. These cars can get away from a good driver if you are not paying attention.
Old Feb 13, 2008 | 07:30 PM
bobby777's Avatar
bobby777
Thx. so when you first start the car up and drive it is T/C mode unless you hit it once to turn it off?
Old Feb 13, 2008 | 07:35 PM
Zee916's Avatar
Zee916
Yes TC is on at startup.
Old Feb 13, 2008 | 11:18 PM
BlackZ06's Avatar
BlackZ06
There are TWO systems that you control ......
Active Handling
Traction Control
There are THREE Combinations that the two systems can work in
DEFAULT (At engine start)
AH - ON
TC - ON
Press the Traction button once and turn them
AH - OFF
TC - OFF
Hold the Traction button for about 3 to 5 seconds ....
AH - ON
TC - OFF
This last is known as COMPETITIVE MODE
RTFM ......
Old Feb 14, 2008 | 12:41 AM
ZeeOSix's Avatar
ZeeOSix
Go here and download a factory owner's manual ... should tell you how it operates, along with other info.
http://forums.corvetteforum.com/show...=owners+manual
Old Feb 14, 2008 | 02:09 AM
lordbones's Avatar
lordbones
Cool, thanks for the tip!
Old Feb 14, 2008 | 10:05 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Not to hijack the original subject, but why the hell does the active handling button work backwards...???
What I mean, is that by pushing the button once, you should go into competitive driving mode, and by pushing and holding for 5-10sec, go into full AH disable. That's how almost evey other car with a similar system works.
Just seems stupid to me that chevy would design it so easy to effectively remove all the safety of AH so easily, yet make is so difficult to just shut off TC.
Old Feb 14, 2008 | 10:29 AM
lucky131969's Avatar
lucky131969
Do you have an owners manual for your car? If not :
https://www.mygmlink.com/pdf/go2cont...01corvette.pdf
Check out section 4
Old Feb 14, 2008 | 10:51 AM
BlackZ06's Avatar
BlackZ06
I'm GUESSING that Chevy did it this way to be "consistent" across all Corvettes ...... remember, not all C5's have AH ... it is an option (JL4) on some model/years
So, with a car that only has TC ... the traction button allows you to turn the system ON or OFF simply by pressing the button. (There is no COMPETITIVE mode on a car that only has TC).
So to remain consistent, pushing that same button on a car that has both AH and TC works the same ... the two systems turn ON or OFF together .....
If you want a "split" (Competitive Mode) system, you need to "request" that by holding the button down for 5 seconds .....
Seems perfectly logical to me ... especially because you do have a warnng when you turn the systems off.
Old Feb 14, 2008 | 11:11 AM
Mike Mercury's Avatar
Mike Mercury
Active Handling
Traction Control
AH - ON
TC - ON
AH - OFF
TC - OFF
AH - ON
TC - OFF
RTFM ......
excellent description for C5's that came with TC and AH
I'd add that the Traction Control is not a racing/performance system. It's designed to help old farts drive on ice and snow
Anyone that's racing - will be hindered (not helped) by the TC system.
Old Feb 15, 2008 | 07:27 PM
401K Z06's Avatar
401K Z06
A little-known feature for you raod racers with oil temperature concerns:
Select Oil Temp from the Gages button first. Then select Comp. Driving mode. Then hit Reset, and Oil Temp will again display, without affecting Comp. Mode.
Then try to cool down when you hit about 280 degrees!
Old Feb 15, 2008 | 07:30 PM
Mike Mercury
Originally Posted by 401K Z06
A little-known feature for you road racers with oil temperature concerns:
Old Feb 16, 2008 | 12:54 AM
Mr.TT's Avatar
Mr.TT
St. Jude Donor '10, '15-'16
You can hit reset after competitive mode is activated and access anything on the DIC without disabling competitive mode.
To Having a hard time understanding
