z06 sway bars
Old Feb 14, 2008 | 06:18 PM
Quickshift_C5's Avatar
Quickshift_C5
Originally Posted by robvuk
The T1 bars are SIGNIFICANTLY larger.
Been looking at getting the T1 bars since I bought the car. I guess I'll contine with my grand plan then.
Old Feb 14, 2008 | 07:35 PM
buoniconti81's Avatar
buoniconti81
t1 bars are impratical.. Id rather save for my aps twin turbo......z06 shocks and sways are just fine.....
Old Feb 14, 2008 | 07:49 PM
KorbenDallas's Avatar
KorbenDallas
I have z06 sways and c6 z06 shocks and it made a big difference. Your car will ride like a sports car now, not a "sporty" car anymore.
Old Feb 14, 2008 | 08:59 PM
T.J.'s Avatar
T.J.
Originally Posted by j84buick
Mine showed up on my doorstep about 30 mintues ago. Thanks Gene!
From that auction for reference:
Measurements for Comparison:
Base C5 Suspension : 23mm-front / 19.1mm-rear
C5 Z51 (97-99 ): 25.4mm-front / 21.7mm-rear
C5 Z51 (00-04) : 28.6mm-front / 23.6mm-rear
*C5 Z06* (01-04): 30.0mm-front / 23.6mm-rear
Thanks for the measurements. I can now buy the bushings.
Old Feb 15, 2008 | 10:42 PM
KingTut's Avatar
KingTut
Default Bars Yes - Shocks No
I would do all mods only one at a time. First do the sway bars as they are very easy to do and quite inexpensive for the results. Not sure I ever read where anyone did not like the change - certainly better cornering.
Next I would consider lowering some with the standard bolts - this is free and the only down side is you have to watch how close you come to curbs and "humps" in the road - but it also gives a nice improvement in cornering with little if any change in straight ahead driving.
Shocks are more for wheel bounce and sharp changes in direction. I put in Bilstiens and after only 2 days took them back out. Much rougher ride just going down city streets. Each to his own there.
Consider looking in the used parts section for mods - these both are usually there and if you buy them right and do not like the result you can always pass them on to someone else who's taste is a bit different than yours and not lose money.
Old Feb 16, 2008 | 08:34 PM
Quickshift_C5
Don't just leave it at that, elaborate more.
I'd like to hear why you think they are impractical. Do you have them on your vehicle? Have you ridden in a car equipped with them?
Thanks!
Old Feb 16, 2008 | 11:23 PM
FOLDNTOP's Avatar
FOLDNTOP
From: Oakville ON "Real Corvettes have folding tops..."
I put 04 Z06 springs, shocks, and sway bars on mine with stock sway bar busings. I also have it lowered on stock bolts. Rides stiffer but I like it much better than the stock suspension...
Old Feb 16, 2008 | 11:37 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I just bought these... I am curious if anyone else put them on. Is there a big difference?
http://cgi.ebay.com/ebaymotors/ws/eB...208962501&rd=1
yes, but I also combined it wit Bilsteins Sports shocks....car handles superb now!
Old Feb 17, 2008 | 07:07 PM
berryj's Avatar
berryj
Originally Posted by sogysailor
Be sure to pop for the poly-bushings, $20. For some reason these seem to squeak with the factory ones. I painted mine red for some extra bling!
http://s69.photobucket.com/albums/i7...t=CIMG0158.jpg
Just wondering where can I find these poly-bushings? Is this something GM sells w/ the Z06 sway bar setup or do I find these from another vendor? How many per sway?
Thanks the info.
Old Feb 17, 2008 | 11:07 PM
soggysailor's Avatar
soggysailor
Default Poly Bushings
A lot of vendors carry these. Check the Corvette Forum Store. I just looked and they have them $15 front $15 rear. I had issues with noise from the front. I believe I just replaced the front ones, it's been a couple of years and no noise.
Old Feb 18, 2008 | 01:56 AM
Bluefire's Avatar
Bluefire
I got my Z06 poly bushings from CF Vendor CCA. Chip is a great guy and has awesome service.
Old Feb 18, 2008 | 05:02 AM
Quickshift_C5
I'm going to be getting new sways and shocks soon. I'm dead set on the Bilstein Sport shocks, but am still deciding on sway bars.
I'm still waiting to hear opinions from members who have experience with the T1 Sway Bars. One member said they are impractical. I'd like to know why...
Doing some checking also...
Hotchkiss Measurements:
Front: 31.75mm
Rear: 25.4mm
T1 Measurements:
Front: 38.4mm
Rear: 27.5mm
Also found a link where someone was testing ALL swaybars. He had this to say regarding the T1 and Hotchkiss:
The T1 bars make for absolutely 100% flat cornering, but are, again, in my opinion, brutal on rough roads. They take all compliance out of the suspension on anything but smooth pavement. Even turning the rebound on my shocks down to *nothing* made no change.
I went back to the Z06 bars after that, but was still having a small amount of rubbing trouble, so I have since installed the Hotchkis bars to see if it will be enough to keep the car off the fenders in long sweepers when autocrossing. The new endlinks Hotchkis supplies make no noise at all, look beautiful, and installation was the same as with the other bars. Ride quality made no perceptible change over the Z06 bars, and the cornering is definitely flatter. Turning up the rebound on the shocks has a far worse impact on ride quality than these bars did. I will be keeping these swaybars
As an extra data point, I talked to SCCA Solo II champ Gary Thomason about his car, and he said that he tried the T1's, and that the car understeered horribly, and that the front bar was simply too big. He said he was going back to an all Hotchkiss swaybar setup to complement his 900# VB&P front spring, which he added since winning on just the Hotchkis bars the year before.
Sounds like the Hotckiss sways might be the way to go for those who don't mind shelling out a bit more dough. Going to dig into it a bit further...
Old Feb 18, 2008 | 07:19 AM
  #33
WKMCD's Avatar
WKMCD
I installed the Z06 sway bars about 2 years ago. Great mod! Last spring I added the Z06 springs. It balanced the suspension and didn't make the ride any harsher. I also run Bilstein Sports.
Just do it!
Old Feb 18, 2008 | 08:48 AM
  #34
berryj's Avatar
berryj
Thanks for the info guys!
Old Feb 18, 2008 | 11:13 AM
  #35
gsxrjack's Avatar
gsxrjack
First suspension mod i did was the z06 swaybars and bilstein shocks, loved the handling at the track but driving in the boson area crap roads every day it was a pain in the ****,,(litteraly),,,I then went to z06 leafs and QA1 adjustable shocks, now i have the best of both worlds, nice handling when i want it and the option of really softening up the suspension for every day driving....
Old Feb 18, 2008 | 06:07 PM
  #36
olefam's Avatar
olefam
Just curious - The car has the Z51 suspension package. Is there enough difference in the swaybar sizes / wall thickness to warrant consideration of this modificaiton?
Thank you.
Glen
Old Feb 18, 2008 | 08:25 PM
  #37
Quickshift_C5
Thank you.
Glen
In my opinion...not the Z06 Sways.
I'm jumping up to the Hotchkis bars myself...
To z06 sway bars
Old Feb 20, 2008 | 05:51 AM
  #38
Quickshift_C5
The Addco sway bars are actually between the Hotchkis and T1 bars in thickness, and are cheaper than the Hotchkis.
Anyone have experience with the Addco rear sways?
Old Feb 20, 2008 | 12:07 PM
  #39
FASST LN's Avatar
FASST LN
I replaced my FE1 (base) suspension with 75k miles on it with ZO6 springs, swaybars, and Bilstein Sports.
I credit the shocks for providing the most positive change. Mid-corner bumps that used to kick my tail-end out by a foot no longer upset the car at all. It is a great confidence booster having the car so settled and poised while travelling over imperfect roads.
The sways did relieve the car of body lean through the corners, but the aggregate effects of the suspension changes have really made my car's handling feel so much more predictable and stable.
It really makes me want to take the car to a road course now!!
(But if something broke, I couldn't afford to fix it)
Old Feb 20, 2008 | 05:56 PM
  #40
motogib1's Avatar
motogib1
I've had that happen many times and I didnt think there was anything I could do about it. Sway bar did not cure this. Sounds like the Z06 shocks did the trick. I wonder if the C6 Z06 shocks (given that they are very cost effective) would be equally successful in curing this problem?
