z06 sway bars
Old Feb 13, 2008 | 09:19 PM
buoniconti81's Avatar
buoniconti81
Default z06 sway bars
I just bought these... I am curious if anyone else put them on. Is there a big difference?
http://cgi.ebay.com/ebaymotors/ws/eB...208962501&rd=1
Old Feb 13, 2008 | 09:29 PM
motogib1's Avatar
motogib1
There is a lot of folks on the forum that have Z06 sways. I bought some in the spring from GMpartshouse for $209 delivered, that is with out the endlinks as I already had metal endlinks on the car. I really like this modification. Noticeable reduction in roll on the corners. Great bang for the buck mod in my humble opinion. I'm thinking of adding C6Z06 shocks to complete the handling package.
Old Feb 13, 2008 | 09:55 PM
914eener's Avatar
914eener
Made the change to my 99 F45. Changed to the metal end links also. Made a dramatic difference. $$ well spent.
Old Feb 13, 2008 | 09:56 PM
veni vidi vert's Avatar
veni vidi vert
Yep... It's an easy do it yourself job (and I'm a do it yourself idiot by this forums standards) that you'll really enjoy..
dig in..
Old Feb 13, 2008 | 10:00 PM
buoniconti81
Thats what I heard......I can't wait!!!!!!!!!!!!!!!!
Old Feb 13, 2008 | 10:10 PM
soggysailor's Avatar
soggysailor
Be sure to pop for the poly-bushings, $20. For some reason these seem to squeak with the factory ones. I painted mine red for some extra bling!
http://s69.photobucket.com/albums/i7...t=CIMG0158.jpg
Old Feb 13, 2008 | 10:49 PM
Bluefire's Avatar
Bluefire
I put Z06 sways with poly bushings on my 03 Coupe (w/ F55 option). There is a lot less roll in turns and floating at speed. These work great with either of the suspension settings. I would consider this a must have mod.
Old Feb 13, 2008 | 11:22 PM
vincentjames501's Avatar
vincentjames501
I would opt for some Hotchkis sways myself.
Old Feb 14, 2008 | 07:10 AM
VET IT B's Avatar
VET IT B
Do the Hotchkis have any squeeking after install?
Old Feb 14, 2008 | 11:03 AM
Bluefire's Avatar
Bluefire
The reason I was able to get these Z06 sways is my friend with a Z06 upgraded to the Pfadt sways. He loves those now.
Old Feb 14, 2008 | 11:07 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi buoniconti81 -
Yes - definitely!
And you'll get even more noticeable improvement if you go with a better shock.
I put 2004 Z06 shocks on the wifes 99, along with the Z06 sways and it really sticks to the road now.
Much better over irregular roads.
You will notice the improvement, and you will like it!
best regards -
mqqn
Old Feb 14, 2008 | 11:21 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Sway bars are one of the best upgrades!
No squeeking here
Old Feb 14, 2008 | 01:18 PM
FKING1's Avatar
FKING1
Put 04 ZO6's on my 2000 2 mos ago. Easy job, but havent driven since.
Old Feb 14, 2008 | 01:41 PM
red88L98convert's Avatar
red88L98convert
i put z06 sways on back on christmas eve. i also lowered the car on the factory bolts. WOW......best 'free' mod you can do and have noticable difference the first time you turn the wheel!! (when i say 'free' mod, my buddy gave me the sway bars and metal end-links!!)
makes circular freeway on-ramps much more fun
Old Feb 14, 2008 | 02:57 PM
Quickshift_C5's Avatar
Quickshift_C5
How would you guys compare the Z06 sways to the T1 swaybars?
Anyone running those?
Old Feb 14, 2008 | 03:00 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
I went with the Z06 sway bars and shocks about 2 years ago. The ride is a bit harsher, but then again I'm lowered on stock bolts with the EMT tires. She rides pretty rough but I don't care.
Did you notice the difference in the size of the stock vs Z06 bars? Substantially thicker!
Old Feb 14, 2008 | 03:16 PM
j84buick's Avatar
j84buick
Mine showed up on my doorstep about 30 mintues ago. Thanks Gene!
From that auction for reference:
Measurements for Comparison:
Base C5 Suspension : 23mm-front / 19.1mm-rear
C5 Z51 (97-99 ): 25.4mm-front / 21.7mm-rear
C5 Z51 (00-04) : 28.6mm-front / 23.6mm-rear
*C5 Z06* (01-04): 30.0mm-front / 23.6mm-rear
To z06 sway bars
Old Feb 14, 2008 | 04:04 PM
ekim7878's Avatar
ekim7878
just did this mod last weekend and I love it! This weekend Z06 Shocks and leafs are going on and lowering 1 inch on stock bolts. Can't wait for the new ride!
Old Feb 14, 2008 | 04:11 PM
robvuk's Avatar
robvuk
The T1 bars are SIGNIFICANTLY larger.
Old Feb 14, 2008 | 05:19 PM
buoniconti81
Anyday and I should have them..........
