tire help
Old Feb 14, 2008 | 10:38 AM
bcartman2's Avatar
bcartman2
Default tire help
i am putting stock Z06 wheels on a 02 coupe, the KDW tires dont come in the same size as the stock Z tires. they only have 255 and 275 for the front wheels, will the 275/40ZR17 fit the front of my car?
Old Feb 14, 2008 | 10:51 AM
lucky131969's Avatar
lucky131969
What do you have the tires on now?
Old Feb 14, 2008 | 11:33 AM
Russ K's Avatar
Russ K
The problem with a 275/40/17 tire is the sidewall is noticeably taller than a 295/35/18 rear tire (stock ZO6 size).
Michelin PS2's are available in 265/40/17 & 295/35/18 sizes, and are the best tires that I've had on my ZO6.
Russ Kemp
Old Feb 14, 2008 | 11:40 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Another important thing to remember when making tire changes--front or back---make sure that you always keep about a 1" split between the front and rear heights--the rears being 1" taller---If you get this too far off your traction contol system will not work properly and more importantly--your ABS braking system will not work properly either--In a panic quick stop--when needed the most !!
Old Feb 14, 2008 | 11:43 AM
bcartman2's Avatar
bcartman2
ok guys, i thought that 265 was the width and 40 was the height , all in MM .....am i wrong?
Old Feb 14, 2008 | 11:49 AM
q8_c5's Avatar
q8_c5
yes it will fit.. but i wouldn't recomend a bigger size(275) for the front its not safe.. but for the rear u can go bigger like 315...i just installed 17x40x255 last week for the front and its fit 100% with no problem..
Old Feb 14, 2008 | 11:50 AM
SDPC's Avatar
0SDPC
Former Vendor
The height in mm would be 40% of 265mm.
Old Feb 14, 2008 | 12:15 PM
bcartman2's Avatar
bcartman2
will the 315 fit on the 10.5 rim without bulging
Old Feb 14, 2008 | 12:21 PM
lucky131969
What is the story with the KDW tires? Have you already purchased them, thinking about it, etc? Obviously, there are other options.
Old Feb 14, 2008 | 12:25 PM
Russ K's Avatar
Russ K
A 315/30/18 tire is only ~25.5" tall, and will bulge on a 10.5 rim.
Russ Kemp
Old Feb 14, 2008 | 12:51 PM
bcartman2's Avatar
bcartman2
i am looking at the KDW's and i have the rims i have heard great things about them. is there a better choice
Old Feb 14, 2008 | 01:03 PM
lucky131969
Dude....your kidding right? There are plenty of choices, mild to wild, that offer factory sizes. Do a little research on tirerack.com, or other websites.
Old Feb 14, 2008 | 03:03 PM
bcartman2's Avatar
bcartman2
there are only 3 tires that come up on tirerack when you check for both sizes. i think i will go with the smaller KDW in the front...
Old Feb 14, 2008 | 03:53 PM
lucky131969
So is this a price issue? I thought the advantage of having the ZO6 rims was the ability to have more rubber.
Old Feb 14, 2008 | 04:11 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
There are plenty of forum members out there that run a 275/40/17 in front with no problems. A popular change is to a 275/35/18 front tire which has an overall diameter of 25.6 which is exactly what a 275/40/17 is, 25.6. Some tires state 25.7. Go to Tire Rack's site a do a little research. Don't limit yourself.
Old Feb 14, 2008 | 08:17 PM
bcartman2's Avatar
bcartman2
really liking the KDW's, fronts are the same diameter but the rears are shorter by .6 inches, will this throw off the traction controll/abs and howbad will the speedo be?
Old Feb 14, 2008 | 10:07 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
should not affect the speedo since that runs off front wheels (i beleive), not sure about the tc/abs. Anybody else got any input?
To tire help
Old Feb 14, 2008 | 11:49 PM
tblu92's Avatar
tblu92
READ MY POST EARLIER IN THE THREAD-- It's your life--if you are willing to gamble with the brakes--that's up to you---
Old Feb 16, 2008 | 10:54 PM
Padrino's Avatar
Padrino
Default now I'm really confused
okay, too much back and forth for me. I like the KISS rule.
KISS....what is the biggest front and rear tires you can run on Z06 stock rims and be safe, not rub, etc.???????
Padrino
Old Feb 16, 2008 | 11:28 PM
FOLDNTOP's Avatar
FOLDNTOP
From: Oakville ON "Real Corvettes have folding tops..."
I had 275 35 18's on the front with 18 X9.5 rims and had no problem.
On the rear I used 295 35 18 on 18X10.5 rims.
I have just replaced them with 275 -30 19 on front and 305 -30 19 on rear with 19X 10 front wheels and 19X11.5 rears.
No Issues
