Clutch Replacement
Old Feb 14, 2008 | 07:04 PM
corvettefreak16's Avatar
corvettefreak16
Default Clutch Replacement
Putting new clutch in a 97 with 95,000. Already ordered new ls7 clutch kit with the flywheel, pressure plate, and disc. I was wondering what else i should replace while i have the driveline and trans out.
Old Feb 14, 2008 | 07:26 PM
k0ts's Avatar
k0ts
Might think about replacing the clutch slave and maybe even the clutch master.. If the slave fails you have a big job changing it out.. You'll have to pull the trans-axle and rear suspension again.
I'm doing a clutch soon and it's only because of both the slave and master going to pot...
Old Feb 14, 2008 | 07:29 PM
Brandon619's Avatar
Brandon619
, also get a remote clutch bleeder.
Old Feb 14, 2008 | 07:49 PM
LEANDRO's Avatar
LEANDRO
I agrees with all of the above.
replace the clutch master, salve, and install a remote bleeder.
Old Feb 14, 2008 | 09:12 PM
randy814u's Avatar
randy814u
New couplers in the torque tube would be a good idea.
It is one of those while you are there things.
Randy
Old Feb 14, 2008 | 09:27 PM
Slow Z06's Avatar
Slow Z06
pilot bearing
Old Feb 15, 2008 | 12:16 AM
Corvette Don's Avatar
Corvette Don
Pilot bearing, rear main seal, slave, master, TT bushings, remote bleeder, rear output shaft seals if your are leaking.
Old Feb 15, 2008 | 03:58 AM
mathia's Avatar
mathia
I just bookmarked this thread about RPM's torque tube rebuild kits: http://forums.corvetteforum.com/show....php?t=1893580
To Clutch Replacement
