any free mods available?
Old Dec 4, 2001 | 12:36 AM
badazz7800's Avatar
badazz7800
Default any free mods available?
on my trans am i did a number of do it yourself mods for a tiny gain? are there any for the C5
Old Dec 4, 2001 | 12:42 AM
99 Corvette's Avatar
99 Corvette
Default Re: any free mods available? (badazz7800)
Lowering and you can cut the stock air box to get more air. Other than that you have to shell out the $$$
Jerry
Old Dec 4, 2001 | 02:02 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
learn how to drive your vette, you would be surprised how many people go the track the first few times and are horrible.
Old Dec 4, 2001 | 09:26 AM
badazz7800's Avatar
badazz7800
can anyone direct me to some instructions on lowering and cutting the air box, thanx, Randall
Old Dec 4, 2001 | 09:32 AM
Scott97's Avatar
Scott97
Here ya go. http://www.corvetteforum.cc/techtips...D=27&TopicID=1
You can also do the throttle body bypass which is almost free.
About $2 worth of parts from pep boys, autozone etc.
Old Dec 4, 2001 | 09:43 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: any free mods available? (Scott97)
You can paint the calipers with Rustoleum for about $8. Isn't free but is very cheap as far as mod prices go.
Old Dec 5, 2001 | 09:49 AM
badazz7800's Avatar
badazz7800
ttt
Old Dec 5, 2001 | 10:03 AM
earlybird_66's Avatar
earlybird_66
Hi Scott,
Do you recommend a throttle body bypass for a 02 C5 too?? If so, do you have any installation info on it?
Thanks,
Old Dec 5, 2001 | 10:42 AM
Red Rage's Avatar
Red Rage
You can aim your fog lamps higher than the factory setting and give your low-beam headlights a boost. Here is a link to instructions:
http://www.cau-llc.com/c5tips.htm
Here are two nearly free upgrade ideas that I like. Replace that junky looking, zinc coated license plate hardware with stainless steel hardware (from your local hardware store). If your state requires a front license plate, use the GM frame ($10) and color match it to your car with touch-up spray paint (about $5) available from GM. You won't be faster, just better looking.
:cool:
Old Dec 5, 2001 | 11:35 AM
CliffB-99's Avatar
CliffB-99
Default Re: any free mods available? (Red Rage)
Take the screen out of the MAF ends.
Old Dec 5, 2001 | 02:37 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
The best and easiest free mod I've found is running 1/8 of gas tank, especially during Saturday night. :D
That save at least 70lbs of weight.
To any free mods available?
