Sensor Question
Old Feb 17, 2008 | 06:48 PM
birch64's Avatar
birch64
Default Sensor Question
does anyone have a picture of the complete sensor how it mounts into the rim? i received my new sensors for my 2000 and it has a O-ring on the base of the sensor, do i need another O-Ring for mounting?
Old Feb 17, 2008 | 07:24 PM
birch64's Avatar
birch64
Found this:
The o-rings (1 on each) go on the stem before you put it through the hole. The nut then gets screwed on.
there is a O-Ring already inbedded into the base of the sensor were the valve comes out of the base do I put another O-Ring over that one?
Old Feb 17, 2008 | 10:03 PM
myk7's Avatar
myk7
Nope.. only one o ring (never reuse an old one).. you are good to go. Look up the torque for the nut though, doesn't take much.
Old Feb 18, 2008 | 01:10 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Tip, especially if you are using other than OEM rims. Get the same size "O" ring but a thicker one. Got mine at Ace. I was putting on aftermarket rims and found this tip just in case the valve holes were a little off. Worked great, no leaks in two years, and only cost a buck or so.
Only use one "O" ring, two might create an area to leak between them. I have a Y2k so the sensors are the same as yours.
Old Feb 18, 2008 | 05:57 AM
birch64's Avatar
birch64
thanks
Old Feb 18, 2008 | 09:05 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
#9 orings by the way........
To Sensor Question
