Change default Imperial to Imperial
my car is a 98 coupe.
A dealer told me to hold the e/m button down for 7 seconds and it'll stay in that display - sure, as long as the car stays on!!
I've even tried holding the e/m button for upwards of 30 seconds - turn the car off for a few minuites and when come back on it's back to imperial.
Can I fix this??
My understanding is that if you have a car built for a "default" of KM/H then your speedometer reads from 0 to 300 .... and if your car was built for a default of MPH, then your speedo reads from 0 to 200 ....
There is no way to change the "default" according to the Service Manual (there may be some "hidden" procedure .... but it isn't in the Service Manual).
By the way, as an aside, the vehicle is not displaying in "Imperial" units, as an Imperial gallon is different from an "American" gallon ... and though the switch is marked E/M for English/Metric the fact is that the UK adopted metric some 20 plus years ago ....
The biggest problem ????? The G**damn French who came up with this whole metric system anyway (and as usual, got it wrong) .... can't we just vote them out of the UN ????? Please ?????
I ain't beens no goods at spellin and crap for a lotta whiles now. And I think proof reading is for geeks. hehe
Lots of people with newer cars seem to be capable of keeping the display they select.
Peter
Set all the controls the way you want them (including the ENGLISH/METRIC to metric) and press and HOLD the MEMORY 1 & MEMORY 2 functions until the little yellow light on the memory switch flashes THREE times.
That way, when you unlock the car with the FOB, everything will revert to your personal settings.
Make sure you set BOTH memory settings just incase your using FOB -1 and set memory #2 or visa versa.
Have you scrolled through the FUNCTIONS pages and seen if there is an ENGLISH / METRIC SELECTION??
If it doesnt stay after that, your on your own!
Bill
I even tried setting memory 3 times and that never worked - then I tried turning the car on and of 7 times - nothing. Anyone know an indian rain dance that might work??
