as is the common experience of corvette drivers, it's quite easy to make the car's rear swap ends, more so with the traction control off. and with a lot of money invested in our cars, this is not a good thing especially when there's a lot of solid objects around.
on the other hand, front drive cars (you know, the kind that many of us use as daily drivers), give you ample warning that its handling ability is reaching its limits by emitting a lot of tire squeal. granted that an understeering car is not the optimum setup for fast lap times, but on the street, it can save a lot of expensive body work.
aside from putting super skinny front tires or massive rear tires, is there any tricks that would make a C5 lean toward an understeering condition than oversteer?
How about driving in a reasonable fashion on the STREET. I think you'll find the car is pretty neutral. If you're driving on the STREET in such a way that the "ends are swapping"...please stay off roads in my area.
On the street the car is almost dead neutral, which on the race track means that you can throttle steer the car very easily. Take a driving class and learn about using your throttle to control the car's handling, adding throttle creates understeer, coming off the throttle creates oversteer. Adding understeer by altering tires or suspension is NOT a good idea, you are trying to get the car to "correct" for your lack of driving skills. Fix your driving habits (slow down if you can't handle the car) and take some classes through groups such as the SCCA, NASA, or even the BMWCCA.
Also, on the street, leave your T/C and A/H on .... they are there for a reason.
Check your alignments, tire pressures and age of your tires.
as BLACKZ06 mentioned a driving school HPDE is the best way to learn car control.
There are very few cars sold today that are set up to oversteer from the factory. Your oversteer is either caused by a suspension problem, or you are giving it too much throttle on corner exit. With a stock setup (or even most modified setups) you should see nothing but understeer at corner entry.
.............. ..............aside from putting super skinny front tires or massive rear tires, is there any tricks that would make a C5 lean toward an understeering condition than oversteer?
Tire pressure.
To increase under-steer, lower the front pressure while increasing the rear.
Do this in 2 pound increments
Tire wear will increase however.
Drive carefully on the street, as stated above the C5 has great handling and to push its limits means you are running awfully hard.
What you are describing is throttle oversteer. LSD aggravates this going around tight corners (I'm guessing you're seeing this when turning at an intersection or other really tight corner, and pretty slow speeds). If this is true, then what you need to do is just wait until the car is pointed straight, then apply however much throttle you want.
But, as Black Z06 stated, go to a driving school. #1, you'll learn how much you don't know about driving, and #2, you'll probably get hooked on just how much your Vette can do, maybe even check out the local autocross scene!
I like the tire pressure and new wider tires idea. You may also try lowing the rear suspension and/or raising the front. I don’t know if it would be a great idea - may cause negative handling - but I’m sure it would do something (positive or negative) and it’s free. The vette is almost perfectly balanced (52/48) but if you put the battery in the back and perhaps lighten up the front by another 50 # or so you could reach the perfect 50/50 or even 48/52 if you desire.
Yes for 95% of all vette drivers ah/tc is all good....but
I turn much faster times at the track with it all off. Same goes on the street for me. If I'm on the freeway cruising ill leave it all on usually, but the second I hit surface streets or the back roads which I do a lot off it is all off. Ive come close to wrecking my car several times because AH or TC came on when I didn't want it to. Nothing worse than hammering through turns and the damn AH coming on all the time cause the computer says I cant drive the car that hard.
Proper ride height and car rake have a lot to do with high speed handling. Slammed cars look cool, somewhat, but handle poorly.
Then also taking into a count the corner balance with the drivers wt in the drivers seat. All these things should go into the handling characteristics of your car.
^^ yes, not using AH/TC applies to you because it would seem you know how to handle the car at the limits. AH and TC is for drivers who does not and it will hopefully get them out of the trouble they are in.
My car is a 98 so it only has TC. I find it keeps the back end from going to far when I overuse the throttle.
