vette wont start
Old Feb 19, 2008 | 11:11 PM
67weaver's Avatar
67weaver
Default vette wont start
I went out to go out 5 minutes ago and I put my key in and turned it and it wont even turn over. I have a feeling that it is something to do with the battery but I am not sure. There's not even a clicking noise how it usually does when a car wont start. If anyone could help that would be great. Thanks
Old Feb 19, 2008 | 11:28 PM
hightest's Avatar
hightest
If there's no clicking noise, and the battery is still showing sufficient voltage; if your car is an auto or M6 check to see if the neutral safety switch is working. Sometimes the shift lever doesn't fully engage into park, try putting the car in neutral and turning the ignition.
If the car is an M6 check to see if the neutral safety switch has power across the switch when the switch is depressed.
Old Feb 19, 2008 | 11:33 PM
67weaver's Avatar
67weaver
Ok, next time it happens I will try that, I went back out and tried it again and it worked so I am going to get it checked out sometime this week. But thank you very much for your help.
To vette wont start
