Partially collapsed lifter?
Old Feb 20, 2008 | 02:07 AM
CharlieB1979's Avatar
CharlieB1979
Default Partially collapsed lifter?
Hey all! I've been checking around about the light "tapping" that's happening under my hood...it could be the result of a partially collapsed lifter...anyone able to give me some details regarding cost and/or how to fix and some details?
Thanks in advance!
Old Feb 20, 2008 | 05:41 AM
vettenuts's Avatar
vettenuts
I would be more suspicious of a rocker losing its roller bearings than a lifter. Lifters are pretty reliable unless something has happened to cause a problem. If you only have one tapping, pull the valve cover and check the rockers. This is a known issue with these rockers and a lot of guys have had them dump their bearings.
Old Mar 6, 2008 | 12:44 AM
peachtreeplaya's C5's Avatar
peachtreeplaya's C5
I think I may have this same issue. I get a tapping nosie then when I shift to the next higher gear the tapping goes away until I get to the limit of that gear then the tapping is loud but then i shift to next higher gear and its gone again. will watch replys to you for help.
Old Mar 6, 2008 | 12:47 AM
thetaxman's Avatar
thetaxman
Originally Posted by vettenuts
I would be more suspicious of a rocker losing its roller bearings than a lifter. If you only have one tapping, pull the valve cover and check the rockers. This is a known issue with these rockers and a lot of guys have had them dump their bearings.
To Partially collapsed lifter?
