z06 plug wires
Old Feb 20, 2008 | 09:07 PM
03blackZ06's Avatar
03blackZ06
Default z06 plug wires
what plug wires are you running and why? im thinking of doing plugs and wires and i want to know what works well for most of you. thanks mike
Old Feb 20, 2008 | 11:18 PM
81c3's Avatar
81c3
GMPP Gene Cully
Old Feb 21, 2008 | 04:53 AM
coolbubba's Avatar
coolbubba
MTI Racing 10mm-awesome quality for $100.
Old Feb 21, 2008 | 05:17 AM
99 HRDTP's Avatar
99 HRDTP
I second the GMPP.
Old Feb 21, 2008 | 08:21 AM
FLATOUT's Avatar
FLATOUT
Temporary Hold
From: www.modular-concept.com www.flatoutimaging.com
I bought a set of Callaway's over Christmas for 100$. They look great but I have not installed them yet.
Andy
Old Feb 21, 2008 | 08:43 AM
dcd58's Avatar
dcd58
MSD 8.5 and NGK Tr55 Great wires for the price ($62)and don't need covers because of headers and well, NGK stands alone!
Old Feb 21, 2008 | 09:16 AM
Conflicted's Avatar
Conflicted
For our cars wires are wires for the most part. The lengths are so short that you are not going to notice a difference between brands, so go with what’s readily available and has the best price. When I installed my long tubes I replaced the plugs and wires at the same time. I would have gone with GMPP but they were out of stock, so I went with MSD instead.
Old Feb 21, 2008 | 10:25 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Magnecore Wires stock plugs. I did not want to change them often or ever
Old Feb 21, 2008 | 11:04 AM
BlackZ06's Avatar
BlackZ06
AC Delco Iridium 41-985 plugs (GM recommended as replacement for the platinum plugs installed at the factory) they come CORRECTLY pre-gapped at 0.040
GM Performance Parts spark plug wires - kit contains 8 wires - kit is part number 12495519
Old Feb 21, 2008 | 12:04 PM
JEFF WHITTINGTON's Avatar
JEFF WHITTINGTON
Thats what I run.
Old Feb 24, 2008 | 11:20 PM
z06inVB's Avatar
z06inVB
Autolite wires...they cost 35 bucks a set and are as good as anything else.
Old Feb 25, 2008 | 01:35 PM
heavymetals's Avatar
heavymetals
Granatelli.
Less then 1 ohm
Old Feb 25, 2008 | 02:40 PM
FasterIsBetter's Avatar
FasterIsBetter
The NGK Iridium plugs are excellent. MSD 8.5 wires are great. I also put wire insulator boots on to protect them as they run very close to the headers. Heat increases impedence, so keeping them cooler can't hurt.
Old Feb 25, 2008 | 05:16 PM
bobdobb's Avatar
bobdobb
Ditto
Old Feb 25, 2008 | 05:26 PM
SS DNA's Avatar
SS DNA
Originally Posted by heavymetals
Granatelli.
Less then 1 ohm
Did you feel a difference from using those ??
I dont mean to bash but they are alot of money and I dont think they make a difference.
Old Feb 26, 2008 | 12:40 AM
heavymetals
Yeah, I felt a differance.
My wallet was a lot lighter!
I run a maggie, so I stuck in the lowest resistance wires out there.
To answer, no I didn't "feel" a differance.
I didn't know you were suposed to "feel" a differance with a wire changeout.
The sparkplugs seem to burn ok though.
Old Feb 26, 2008 | 12:41 AM
bullitt4110's Avatar
bullitt4110
Wires are wires on these cars, unless you want colored ones.
To z06 plug wires
Old Feb 26, 2008 | 06:57 AM
PA Z06's Avatar
PA Z06
Originally Posted by 81c3
GMPP Gene Cully
x2 I think I got the hot wires but they were cheap from gene
Old Feb 26, 2008 | 07:59 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you will gain NOTHING with wires other than a change in color; I've found the MSD wires to a be bit 'frail' in my experience
the new LS2 wires are the best to work with(from gm)
Old Feb 26, 2008 | 09:41 AM
jovette's Avatar
jovette
GMPP (red) wires and NGK TR 55 Iridium spark plugs for me.
