Trick Flow Heads CC's
Much like the AFR's, I had Tony Mamo do the work on mine since he knows the in's and out's of the heads.
We would be more than happy to help you out with your cylinder heads. We have been working with Brian for over 6 years now and have developed quite a relationship with him and his crew.FWIW, We use TFS 215s on 90% of our heads/cam packages and most are milled down to 58-61cc .... Rest assured they still flow quite well with a few thousanths off the deck
week. Thnx.
59cc will land you in the 11.5-11.7 ballpark depending your head gasket choice.
Simply put, static compression means a lot of nothing.
Dynamic compression, (which takes into account how much the cam overlap bleeds off cylinder pressure) means everything, in terms of what you can get away with with pump gas.
For example, 11.7:1 static is not a problem if you are running a large 240s duration cam with 20* overlap. That's exactly what I'm doing, and it works great on 93 octane.
However, that same SCR (static compression) with say a 224 cam, your DCR (dynamic compression) would be way too high, and pinging would likely result.
For 93 octane, a DCR of 8.5-8.7 is ideal. If you know all your cam specs, and have Excel, this DCR calculator will help you out:
What gains have you seen with trick flows vs afr heads?
Could you also send me a quote on some milled trickflows (please include gaskets and install hours).
Thx
