tuning and data logging questions need help
His site is: http://www.highpressuremotorsports.com/
talk to you soon
Jeff
The LS1/Corvette setup produces the most power/torque at WOT with 13.2/13.4 until about 3200 rpm, then 13.0/12.8 from 3200 to 4400 and finally 13.0/13.4 from 4400 to redline.
I would think the tuner will want to see timing (including absence or exhibit of Knock Retard), MAF, rpm, MAP and fuel trims to determine what amount of compensation the PCM is applying in closed loop. One interesting thing, is if the PCM senses a lean condition, and has to add fuel to bring the AFR back to the stoich 14.7,:1, it also adds that percentage of additional fuel to the commanded air/fuel ratios in PE or open loop, making them a bit richer or "safe".
One thing if you could, would be to disable the MAF and let the PCM drop into Speed Density. From here the fuel trims can be monitored to allow "tweaking' of the VE tables (a fixed air flow rtable based on stock which is used if and when the MAF circuit fail) if he deems necessary. Depending on your setup, it may be as easy as pulling the MAF connector, driving around for 50-100 miles, then logging fuel trims against RPM and MAP. Talk to him about your setup or he may feel this isn't necessary with only bolt-ons, but if your airflow is increased as much as they think, it will help in the quick throttle transitional points.
Well as you see, you can go on an on and on....sorry
Good luck and let us know on the final numbers. My numbers were close to yours (see sig below) when Carmen finished the bolt on phase, but the tune really came to life with the torque, which after all is really what we are after
The WOT tuning is very difficult without a wideband and will be kept a bit conservative to be safe.
Ed
It's tough when you can't see inside. That is why I went and bought HPTuner, so I can work with my Tuner and "help" as I call it.
Ed
I was asking as to see if the g/sec truely are much higher, based on your mods which would "saturate" the MAF. I wouldn't think so though .
Ed
at 3000 rpms a/f is at 14.6 to 1 @wot, maf 125.03 g/s, map 99 kpa or 4.75v
at 4000 rpms a/f is at 14.1 to 1 @wot, maf 174.35 g/s, map 98 kpa or4.69 v
at 5000 rpms a/f is at 13.0 to 1 @wot, maf 231.98 g/s, map 97 kpa or 4.64 v
at 5500 rpms a/f spikes to 13.5 to 1@wot, maf 251.30 g/s, map96 kpa or 4.59 v
long term ft were at 10%
i do not pretend to know how to tune but i do know 15 to 1 @ wot is to lean the tuner runing the dyno aborted the pull every time it lean spike and it did it everytime at the same rpm (5500 give or take 50)
i think the reason they feel there is more on the table as far as hp is that it was still climbing when he aborted the pull the reason they feel there is more torque left on the table is that its 14 to 1 at where peak tq should be
it did make above 300 rwtq from 2000 to 5500 and i hope this is enough info but i honestly do not know thanx again if u can compair this
Where is the AFR being monitored? You don't have any exhaust or intake leaks, do you?
I am sure once the Tuner gets into, he will find it.
Ed
