Wind noise problem
Old Feb 23, 2008 | 04:06 PM
glide's Avatar
glide
St. Jude Donor '13,'19
Default Wind noise problem
I have recently bought a 99 FRC. Lots of noise coming from the trunk area so I bought a cheap partition. Now I get a lot of wind noise from the front of the drivers window. What is the fix for this? By the way I leaned against the car the other day and the driver side weatherstripping came off. I just stuffed it back where it was but seemed to be poor quality for it to come off to begin with, Noise started before anyway, New weatherstripping , window adjustment or what?
Old Feb 23, 2008 | 04:23 PM
SSWEET's Avatar
SSWEET
You might search the forums for a window "tip in" adjustment procedure.
Old Feb 24, 2008 | 10:28 AM
glide's Avatar
glide
Default FRC Wind noise
Require removal of door panel. You don't think its the weatherstripping since its so flimsey? Any other FRCs having this problem?
Old Mar 3, 2008 | 04:28 PM
RoadVette1999's Avatar
RoadVette1999
Glide,
It does not require the removal of the door panel. Just a rubber stop on the bottom of the door and the red reflector inside the door.
Old Mar 5, 2008 | 05:28 PM
glide's Avatar
glide
Originally Posted by RoadVette1999
Glide,
Thanks, sounds like its worth a try.
Old Mar 5, 2008 | 05:39 PM
c5streak's Avatar
c5streak
http://www.theredlion.us/TipIn.htm
Try this!
Old Mar 5, 2008 | 05:56 PM
glide's Avatar
glide
Originally Posted by c5streak
Nice, Thanks
To Wind noise problem
