Replacing Brake Lines
Old Feb 23, 2008 | 06:28 PM
Safedog's Avatar
Safedog
Default Replacing Brake Lines
All....
Can I replace my brake lines without having to bleed the whole system? I am replacing the brake lines, rotors, calipers, pads, etc. Since I am a Safety Engineer, thought it was time!
Thanks in advance.
Karl
Old Feb 23, 2008 | 07:30 PM
Last C5's Avatar
Last C5
You're going to have to bleed the system if you change the lines. If by "whole system" you mean that the dealership will have to use a Tech II on the ABS, then no, you won't have to do that.
Old Feb 23, 2008 | 07:37 PM
Safedog's Avatar
Safedog
Thanks. Is there a "how-to or DIY" to bleed the brake system somewhere?
Is it stated in the Service Manual somewhere and if so, could some send to me?
Many Thanks.
Old Feb 23, 2008 | 08:43 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
get yourself a pressure bleeder. about $50. It makes the job a breeze and completed in 20 mins.
attach to reservoir. Put in some brake fluid. close, pump up. bleed each brake with hose attached to catch fluid. next wheel.
Old Feb 23, 2008 | 08:48 PM
71corv's Avatar
71corv
St. Jude Donor '08
Speed bleeders would be helpful also.
Gene
Old Feb 23, 2008 | 10:05 PM
Safedog's Avatar
Safedog
If I go with the Speed Bleeders, do I need the pressure bleeder?
Old Feb 23, 2008 | 10:19 PM
BlackZ06's Avatar
BlackZ06
For your 2001, the correct bleed sequence is ....
Right Rear
Left Front
Left Rear
Right Front
Old Feb 23, 2008 | 10:57 PM
Safedog's Avatar
Safedog
Gene
Old Feb 23, 2008 | 11:04 PM
BlackZ06's Avatar
BlackZ06
It's kinda either/or .....
The pressure bleeder allows a single person to bleed the brakes because the pressure bleeder eliminates the need for someone to pump the brake pedal. The lone person simply goes to each bleed screw (in the correct sequence above) and opens each screw until that caliper is bled. With the Sped Bleeders, a single person can still bleed the brakes, but they have to pump the pedal and hope they can see hat the fluid is coming out cleanly from each caliper. The speed bleeders simply eliminate the need to close the screw between each pump of the brakes.
Personally I prefer the pressure bleeder systems.
Old Feb 23, 2008 | 11:22 PM
Safedog's Avatar
Safedog
Thanks all. Decided to go with the Speed Bleeders and Valvoline Synpower DOT3 & DOT4.
When the weather warms up a bit here in extreme Upstate NY I am doing a complete reinstall from Fluid to SS Brake lines to Powerslot Rotors(Zinc Coated-Slotted and Dimpled) to Speed Bleeders to Powdercoated Brackets & Calipers to new Ceramic Pads to SS Pad Covers....
This is a first time auto monkey project for me...so wish me luck!
Old Apr 16, 2008 | 11:39 PM
jgump's Avatar
jgump
To Replacing Brake Lines
