Another clutch question
Old Feb 23, 2008 | 06:29 PM
Venomized03's Avatar
Venomized03
Default Another clutch question
I will be ordering a clutch for my 01 Z06 on monday, so it gives me about 1.5 days to decide what I am going with. I need info from your experiences. I want to make sure I go with the "right one" b/c its a pain to do a clutch in the vettes so I dont want to have to replace it anytime soon.
Just so you know how the car will be driven b/c that matters alot on the decision. The car will be driven on the street everyday and I will take it to the track every once in a while. I usually only go when I do more mods to the car. The car is a full bolt on with a cam only. It will be on MT Drag Radials at the track though.
I was thinking about the new Centerforce DFX. I had one in my 03 cobra and loved it. The clutch was very soft and grabbed awesome when I wanted it to. Although I only had about 1k miles on it before I sold the car. I am looking for something strong but easy on the leg b/c its my DD.
Old Feb 23, 2008 | 07:43 PM
derty01's Avatar
derty01
http://forums.corvetteforum.com/show....php?t=1947325
Give them a call since they're having a discount. A lot of members will recommend this clutch. Do it right the first time and go with these. I will be getting one once I get my cash saved up. Heard so many good reviews on this clutch, to me from what I read it's the best on the market.
Old Feb 23, 2008 | 10:23 PM
Brad@RevXtremeAutoSports's Avatar
Just a little advice if I may, get a remote bleeder, change out all your hydraulics to 2004, consider a heavy duty tunnel plate and check your torque tube bushings as well. You are there anyways, these are things to consider.
Best of luck
Old Feb 24, 2008 | 07:50 AM
vettenuts's Avatar
vettenuts
I went with the Textralia x-grip because it holds more power (less than the z-grip) but is more street friendly.
Old Feb 24, 2008 | 08:49 AM
jeanlucpicard's Avatar
jeanlucpicard
I am getting ready to do a clutch job myself and was looking at the Textralia but have recently heard they are having quality problems leading to failures. I am still looking at whose clutch to run with. I autoX a lot and drive my car "like I stole it" most days - not my daily driver - so I need a rugged but reliable clutch.
Old Feb 24, 2008 | 10:04 AM
vettenuts's Avatar
vettenuts
I have not seen this, were the specific instances? One reason I went with Tex is when a problem does occur, they seem to stand behind the clutch better than any other vendor.
Old Feb 24, 2008 | 11:29 AM
jeanlucpicard
I'm in the Houston area and ALL OF WHAT I KNOW IS HEARSAY.
I have been told by a few folks who installed the Textralia they have lost the clutch disc itself. Local shops like Corvettes of Houston and MTI did the installs so I very much doubt it is an installer issue - those shops are top notch. I do not have any details other than the above and in no way am I flaming the Textralia - it is my first replacement choice to use - but I am looking to verify or see if others are encountering the same problem.
Old Feb 24, 2008 | 05:31 PM
vettenuts's Avatar
vettenuts
The only thing I can say is each time there has been an issue with the Tex (other than all out abuse), they have stepped in and helped the owner. In some cases the customer service was incredible. This was one of the big selling points for me when I made my decision. Especially since it wasn't a job I wanted to do again any time soon
Old Feb 24, 2008 | 06:45 PM
GettReal's Avatar
GettReal
You are on the right track... the DFX is the way to go.. Im sure the Tex is a great clutch but its at least twice as much. I have yet to hear someone tell me the DFX isnt good. As mentioned in other post, you only want to go in there once, get the remote bleeder and put in a new Slave, all slaves for C5s are now the same for all years.
Old Feb 24, 2008 | 08:10 PM
vettenuts's Avatar
vettenuts
I think anyone who has done this job will agree that the remote bleeder is worth its weight in gold. I am not sure I could have actually bled the clutch without it, and if I did, I would likely still smell like brake fluid
Old Feb 24, 2008 | 08:45 PM
Venomized03
Awesome. Whare is the best place to buy a remote bleeder?
Old Feb 24, 2008 | 10:06 PM
Corvette Don's Avatar
Corvette Don
I have a Centerforce Dual Friction 12" version good to 675 RWTQ and it has stock pedal feel
Old Feb 24, 2008 | 10:34 PM
GettReal's Avatar
GettReal
Its on sale right now.... http://www.thelapd.com/index.php?mai...roducts_id=194
Call Hanna at LAPD
(818)998-3966
Toll Free (877)843-5173
Old Feb 25, 2008 | 06:15 AM
vettenuts's Avatar
vettenuts
I like the new setup that RPM just came out with.
Old Feb 25, 2008 | 09:31 PM
Venomized03
Any links to the product?
To Another clutch question
