Low Pressure Tire Sensor 1999
Old Feb 24, 2008 | 04:00 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Default Low Pressure Tire Sensor 1999
Put On New Tires Now The Low Pressure Light Comes On. Is Their A Reset. Thanks
Old Feb 24, 2008 | 04:11 PM
jrose7004's Avatar
jrose7004
Yes, you can push reset right of the steering wheel where the DIC buttons are.
Old Feb 24, 2008 | 04:13 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Did you reuse your sensors with the new tires?
Do the new tirs/wheels have sensors installed?
Old Feb 24, 2008 | 04:34 PM
jarsdad1's Avatar
jarsdad1
Is the pressure in the tire(s) low? Many times installer set it too high. Did these guys get it right?
Old Feb 25, 2008 | 02:18 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
i have the same problem except i cant even see how much pressure is in it with a tire guage.
Old Feb 26, 2008 | 07:29 PM
slicker's Avatar
slicker
I had trouble with mine too after I put new tires on
After I disconnected the battery neg cable I waited a few minutes to reinstall
then I let all the air out of the tires to about 10 lbs and reiflated to 30lbs
after that the sensors were working again
I don't know which did the trick but they work now
Old Feb 27, 2008 | 09:36 AM
87SAM's Avatar
87SAM
I don’t understand You can’t read the pressure with a tire gauge Do you have run flats with no air?
Old Feb 27, 2008 | 12:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WTF???????????? Add 30 psi to your tires then use the gage. See if that fixes the issue.
If you cant read the pressure with the pressure gage, one of three things are wrong.
NO pressure
Pressure Gage is bad.
There is something in the stem blocking the small valve needle. (this happened to me once when I installed an after market valve cap. )
BC
To Low Pressure Tire Sensor 1999
