GM warrenty exceptions
Ron
A dealership might have had a voice with GM but you needed a very close relationship having gone in for all services on the vehicle with that dealership. They also should have discussed a extended warranty for the low mileage vs the car's age.
good luck
Document ID# 1206539
2001 Chevrolet/Geo Corvette
Engine Knock or Lifter Noise (Replace O-Ring) #02-06-01-038 - (Dec 2, 2002)
2001-2002 Chevrolet Camaro
2001-2003 Chevrolet Corvette
2001-2002 Pontiac Firebird
2002-2003 Cadillac Escalade, Escalade EXT
2000-2003 Chevrolet Suburban, Tahoe
2001-2003 Chevrolet Silverado
2002-2003 Chevrolet Avalanche
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Sierra
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U -- RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
Condition
Some customers may comment on an engine tick noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
Cause
The O-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
Correction
Inspect the O-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
12557752
Seal-O/Pmp (O-ring)
(F and Y Cars)
1
12563963
Seal-O/Pmp (O-ring)
(C/K Trucks)
1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Usage
Labor Time
J1060
Pickup Tube and Screen - Replace
F Car
3.7 hrs
Y Car
4.3 hrs
C Truck
1.3 hrs
K Truck
2.1 hrs
so if they say not covered, tell them you want to speak to the factory rep.
If not, you need to call GM's 800 number and speak to someone regarding your problem. They will tell you to get it fixed and send them the reciept. They will pay for itThe Best of Corvette for Corvette Enthusiasts
The dealer can go "plead" your case with the GM zone rep. The dealer is not gonna let you (nor will the zone rep let you) talk directly with the rep. The dealer is the reps "customer" ... not you. The other choice (and the more likely one) is the dealer will ask you to call the GM Customer Assistance line (800) 222-1020 and open up a "case" with them.
The Cust Asst agent will need a bunch of information ... VIN number, dealer that is working on the car, and key, they will ask if you've talked to the dealer first. If you haven't, they will blow you off, so be sure to have discussed this with the dealer management first. Again, be calm and professional in explaining the circumstances, and let them know you are looking for assistance in fixing this problem. ANYTHING that you can offer them that helps your case ... such as (for example) you own 3 other GM vehicles, give them the VIN's from those vehicle's too. Anything that sells GM on the idea that you are and want to continue to be a repeat customer will help your case.
They will probably ask for a day or two, and then get back to you with GM's "decision" on what, if any, help GM will provide. I guarantee they will talk with the dealership in the interim.
You never know, GM may pay for parts, pick up part of the labor ... it never hurts to try.
Best of luck, maybe it will turn out to be something simple and cheap to fix .....
Ron
According to this post...
http://forums.corvetteforum.com/show....php?t=1946659
Is the car absolutely original and unmodified in any mechanical manner? That also might help your case.
Personally, I wouldn't own a C5/Z06 without some type of extended warranty.
Talk with MANAGEMENT at the dealership first. The dealer has NO reason to "protect" GM. If they can get GM to help in paying for your "issue" ... they look like heroes ... and if GM won't help, the dealer can blaim GM ... not themselves.
Work WITH the dealer on this issue, it is in the dealer's best interest (and obviously yours) for GM to pay at least some part of this repair. Whatever GM pays costs the dealer nothing, and probably contributes to your willingness to do business with them in the future.
If you feel the dealership is not being "smart" about how to deal with GM ...... call the GM Customer Asssistance line (number provided in my post above) and CALMLY AND PROFESSIONALLY explain what is happening. My experience has been that while it takes time to work through an issue, (days to weeks .... this ain't gonna be solved in a 30 minute TV show time frame), GM does actually try to help out. I doubt GM will pick up the entire cost of the repair, but it is possible they will agree to pay some part of the cost.
Best of luck,
