3.42 ???'s
Old Dec 5, 2001 | 02:55 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Default 3.42 ???'s
Are there any DISadvantages to upgrading to the 3.42's (besides losing gas mileage)? Wear/stress/trans logenvity? WIll I lose top end power? I'm on the fence on this mod.....
Old Dec 5, 2001 | 03:08 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: 3.42 ???'s (revo1059)
You might lose a hair at the top end, but you will never notice it.
The largest disadvantage is that it will hurt your wallet.
Old Dec 5, 2001 | 03:10 PM
OhSoBlue02's Avatar
OhSoBlue02
Well, higher gears would put a slightly higher stress on the drivetrain but not enough to worry about unless you're building a 600 rwhp monster hehe. You'd lose a little mileage, and a little top end (run out of gear, not power). Other than that you'd have better acceleration across the board.
I'm planning on going to 3.42's myself when money permits. The difference, numerically, isn't that big really. Someone posted an RPM chart showing 2.73's, 3.15's, 3.42's and 3.73's at the same MPH and the difference is surprisingly small going from say 3.15's to 3.42's.
Old Dec 5, 2001 | 06:58 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
I lost about 3 m.p.g @ highway cruzing speed (over 80 MPH) when I switched from my stock 2.73 gear to the 3.42 gears. Along w/ the PL II, its the best mod I've done to my '98 Coupe. Regards---and by the way---Change Those Gears!!!
Old Dec 5, 2001 | 07:37 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: 3.42 ???'s (BiggieBoy)
Its an 8.5% change. Not much, yes; but 3.42 is as far as a regularly driven A4 can be taken without having traction issues...
vstella's Avatar
vstella
This is the second best mod I have done.Just do it!Be sure you have someone who KNOWS what they are doing to install.
Pics of my Install on my homepage below....
The first was the Transgo Shift Kit:D
Old Dec 5, 2001 | 08:28 PM
Purerock105's Avatar
Purerock105
Default Re: 3.42 ???'s (vstella)
vstella,
I have the Powerloader II on order programmed with 3.42's. I'm on the fence with the aftermarket torque converter. I also see that most who DO the 3.42
have one. I don't track the car at all, so I'm not looking to shave a 10th off my quarter mile time. It is REALLY to my advantage to get one? :)
[Modified by Purerock105, 7:29 PM 12/5/2001]
Old Dec 5, 2001 | 08:33 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: 3.42 ???'s (Purerock105)
well you would track it Mark if you'd come down to Bradenton with us....I don't plan on being a regular racer but will hit the track occasionaly, so I'll change the converter when I do the gears.
if for nothing else, it snaps up the performance of the car and you'll have that "new vette" feeling back :D
To 3.42 ???'s
