I really need some help!!!!!
The engine goes from the machine shop to the installer, it all gets installed...bad vibration@ 1800 on up the scale. Worse @ 1800 to 2500. NOW, I'm asked "did you have the engine balanced"? Nice time to ask me!
Hey, I never professed to be a mechanic. I'm just a guy with a wallet trying to trust people. So, we remove the engine again and take it back to the engine builder. I expressed my displeasure to this group, as I would have expected to have been asked " Would you like to balance the engine"? I think that's a reasonable question. Nonetheless, he balances the engine completely ( a very detailed process ) according to the Centerforce literature all of the clutch components are zero balanced. However I brought the clutch to the balancer anyway. We reinstall the engine and guess what? The vibration is still there.
I am at wits end, have no idea what to do next. Car runs like a scalded dog @ 15 lbs of boost. Don't have Dyno numbers yet, but expect them to be in the 700+ wheel category.
Searching for the next step? Please return me to my sanity!
Well...until you get the vibration resolved...stop doing that. You did not mention what type of engine it is i.e. LS1/6 etc. Also, how does it idle? Any vibration at idle? Typically, if the clutch assembly is out of balance, you will know it as soon as fire it up.
"You know, we can pick all the best components and build what should be a great engine, but if I were you, I'd buy a (documented HP-output) crate engine that was assembled at the factory. This way, I can guarantee you that you'll have a 100,000 mile + engine in which EVERYTHING works well together.
Yes, there are some shops that crank out a reliable and potent powerplant everyweek, but they are very hard to find. Take my advice - get the crate motor and go fasy; it's as easy as that!"
Well, he was absolutely right. My ZZ3 C3 was a rocket that never gave me a headache.
Anyway, I do know how you feel and it is VERY frustrating. Have patience and try to isolate what could've been done wrong. SOMEONE has had the same problem; hopefully, he will chime in.
i would take it here and they are in tampa.
http://www.revxtreme.com/
Keep the ideas coming.
Thank You!!
Anything in the rotating assembly could cause the problem. This includes the flywheel, clutch, harmonic balancer, blower drive and blower itself. Since you've pretty much ruled out the clutch/flywheel along with crank/rods/pistons because of the balance job, then check to be sure the harmonic balancer is on correctly. While you're at it, check to see that the flywheel is installed correctly and is running true(I have seen them slightly cocked on the crank).
Easy way to check blower is to simply take it off and see if the engine runs smoother.
You might check around to see if anyone has any vibration analysis equipment. It's usually tough to do anything with a recip but with a simple out of balance condition, they should be able to narrow it down for you. Might be better than hit or miss.
Good luck.
