Bulb question
Old Feb 29, 2008 | 03:48 PM
Crewrow's Avatar
Crewrow
Default Bulb question
On auto transmission is there a bulb under the gear selecter or just the red box that shows selected gear?
Old Feb 29, 2008 | 04:09 PM
DeeGee's Avatar
DeeGee
Automatic transmission indicator
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Old Feb 29, 2008 | 04:19 PM
Crewrow's Avatar
Crewrow
Awesome, thanks!
Now the million dollar question...How do I get to it lol?
Old Feb 29, 2008 | 05:29 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Document ID# 423834
2000 Chevrolet/Geo Corvette
Floor Shift Control Boot Replacement
Removal Procedure
Remove the console. Refer to Console Replacement in Instrument Panel, Gauges and Console.
Remove the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory in Instrument Panel, Gauges and Console.
Remove the floor shift control ****.
Using a flat-bladed screwdriver, carefully pry the staple clip from the ****.
Remove the **** from the floor shift control.
Remove the floor shift control from the vehicle; to allow for boot replacement without possible damage to the boot retaining tabs. Refer to Floor Shift Control Replacement .
Remove the floor shift control boot from the floor shift control.
Carefully squeeze the front and side tabs or the rear and side tabs at the same time in order to release them.
Carefully squeeze the remaining tab in order to release it.
Release the snap lock retainer on the LH side of the boot.
Move the boot to the left and release the shift indicator guide pin from the shift control lever.
Disconnect the indicator lamp socket from the boot.
Remove the boot from the shift control.
Installation Procedure
Install the floor shift control boot to the floor shift control.
Position the boot onto the shifter.
Align the shift indicator guide pin to the slot in the boot, then move the boot to the right to insert the guide pin into the slot.
Connect the shift indicator lamp socket to the boot.
Evenly insert the tabs until the boot locks into position.
Install the floor shift control to the vehicle. Refer to Floor Shift Control Replacement .
Install the shift control ****.
Install the **** onto the shift control.
Install the staple clip.
Install the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory in Instrument Panel, Gauges and Console.
Install the console. Refer to Console Replacement in Instrument Panel, Gauges and Console.
Old Feb 29, 2008 | 05:31 PM
screw991le's Avatar
screw991le
Document ID# 423838
Removal Procedure
Place the vehicle on a level surface.
Block the wheels to keep the vehicle from moving.
Apply the parking brake.
Shift the floor shift control into PARK.
Turn the ignition to OFF and remove the ignition key.
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable.
Disconnect the floor shift control electrical connector.
Disconnect the IP wiring harness retaining clip from the shift control and reposition the harness.
Using a small flat bladed screwdriver or other suitable tool, release the tab retaining the park/lock cable to the slot on the shift control.
Lift the park/lock cable out of the shift control slot and reposition the cable.
Grasp the cable end and pull rearward in order to unlock the cable from the shifter pivot arm stud, then reposition the cable.
Remove the nuts retaining the shift control to the driveline tunnel.
Shift the floor shift control into FIRST. This will lengthen the shift control cable and provide slightly more movement.
Important
DO NOT lift the floor shift control any more than shown, the shift control cable rod end guide tubes are EXTREMELY INFLEXIBLE and capable of only a SLIGHT bend.
Slowly lift the floor shift control JUST ENOUGH to access the shift control cable end. BE SURE the floor shift control remains in FIRST.
Important
Use care to not suddenly jerk either the shift control cable or the floor shift control during disassembly, the shift control cable rod end guide tubes are EXTREMELY INFLEXIBLE and capable of only a SLIGHT bend.
Using a large flat bladed screwdriver, CAREFULLY release the shift control cable end clip from the floor shift control arm stud.
Ensure that the shift control cable is completely disconnected from the floor shift control arm stud.
Remove the floor shift control.
Important
Be sure to position the floor shift control as LOW as possible, the shift control cable rod end guide tubes are EXTREMELY INFLEXIBLE and capable of only a SLIGHT bend.
Lower the floor shift control into position. BE SURE the floor shift control remains in FIRST.
Align the shift control cable end to the floor shift control arm stud.
Important
Use care to not suddenly jerk either the shift control cable or the floor shift control during assembly, the shift control cable rod end guide tubes are EXTREMELY INFLEXIBLE and capable of only a SLIGHT bend.
Position a large pry bar along the side of the driveline support assembly and use as an aid to secure the shift control cable end clip to the floor shift control arm stud.
Seat the floor shift control to the driveline tunnel.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the nuts retaining the floor shift control to the driveline tunnel. Tighten
Tighten the floor shift control retaining nuts to 10 N·m (89 lb in).
Verify that the floor shift control and the shift control cable are operating smoothly:
Shift from FIRST to SECOND, then DRIVE and so on; pause for 1 second in each detent position. Take note of an audible sound from the transmission shift lever each time a shift detent is selected.
Shift from PARK directly to FIRST.
Repeat steps 7.1 and 7.2 an additional 2 times.
If any binding is felt during this check, or if no audible sound was produced from the transmission shift lever, remove the floor shift control and inspect the floor shift control and the shift control cable for damage (at either end of the cable).
Install the park/lock cable to the floor shift control pivot arm stud. Align the cable onto the arm stud then pull forward to lock.
Insert the park/lock cable into the slot on the floor shift control. Be sure the cable retaining tab locks into place.
Connect the IP wiring harness retaining clip to the shift control.
Connect the shift control electrical connector.
Important
Prior to restoring battery power, check to be certain that the ignition key is removed from the ignition switch.
Connect the negative battery cable. Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
Program the transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry.
Unblock the wheels.
Release the parking brake.
Caution
Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage.
Test drive the vehicle in an area with little traffic; ensure that the transmission will shift smoothly into, and maintain each detent position.
Old Feb 29, 2008 | 05:37 PM
Crewrow's Avatar
Crewrow
Holy crap that's a lot of information...
So all of that to replace a bulb?
Old Feb 29, 2008 | 06:03 PM
screw991le's Avatar
screw991le
You need to get the center console off, then the shift boot housing. It looks like a lot, but it is not.
Old Feb 29, 2008 | 09:49 PM
thetaxman's Avatar
thetaxman
takes about 20 minutes to pull it apart if you have a beer in one hand
To Bulb question
